Rack plug - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 9 replies and been viewed 2576 times.
post #1 of 10 (permalink) Old 12-27-2007, 03:02 AM Thread Starter
cumminsdiesel's Avatar
Rack plug
This may be a dumb qestion but what is a rack plug kit?
cumminsdiesel is offline
post #2 of 10 (permalink) Old 12-27-2007, 05:47 AM
I believe it is a plug to get more rack travel, but I dont know the specifics.
post #3 of 10 (permalink) Old 12-27-2007, 07:45 AM
Its the plug in the end of the pump, I believe its used for assembly purposes :shrug: On any pump besides a 215 you can replace the plug with a 2095, "mack" plug or shim it with washers to gain an extra 2mm of rack travel.
http://competitiondiesel.com/forums/...ead.php?t=3537
Dual K20s is offline
post #4 of 10 (permalink) Old 12-27-2007, 10:33 PM
Hmmm where could I find one of these 2095's????
post #5 of 10 (permalink) Old 12-27-2007, 11:13 PM
There only around $15 at a cummins dealer. I'm sure a pump shop could get you one, but a cummins is probably the best bet. The number is 1413462095-00 according to that picture
post #6 of 10 (permalink) Old 12-29-2007, 12:22 AM
The plug is what limits the allowable rack travel if the AFC and plate are modified, the 2095 is 2mm deeper than the 2000. Find a Bosch dealer PN#1413462095, torque it to 45ft/lb.
imported_Smokem is offline
post #7 of 10 (permalink) Old 12-30-2007, 05:49 AM
PDR sells them too for the same price, so they are pretty easy to come by. Note what smokem said too, about the AFC and Plate, remember if both of those aren't modified you won't be seeing any benefit from the Plug, because they will be limiting rack travel before do its thing.
post #8 of 10 (permalink) Old 01-04-2008, 02:15 AM
You can put it on a 215 pump just the same as any other pump!
thekidfan is offline
post #9 of 10 (permalink) Old 01-04-2008, 02:31 AM
But Ive heard with a 4k GSK and running without a plate could cause it to stick at WOT or somethin.
post #10 of 10 (permalink) Old 01-04-2008, 05:30 AM
You can install it on an 887 or 913 pump, but it is detrimental. The rack plug in itself will not allow the rack to hang, however a 4K GSK and a #0 full forward has the tendancy to cause the governor arm to hang under the plate.
