GSK Install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 24 replies and been viewed 9393 times.
post #1 of 25 (permalink) Old 01-11-2008, 12:02 AM Thread Starter
cumminsdiesel's Avatar
GSK Install
I was wondering how hard a GSK install is to do. I know were its at, but do I need special tools and does the pump have to come all the way off? I am pretty mechanically inclined but does the kit have any instructions? Also whats everyones opinion on wich one. The 3000 or the 4000. Is there a huge diffrence in the two? And if I do a 4000 do you have to do new valve springs. I can hit 3,200 rpms right now so what is a 3000 going to do? Thanks everyone.
cumminsdiesel is offline
post #2 of 25 (permalink) Old 01-11-2008, 04:11 AM
I think its easy, especially once you get the hang of it. I go in the side and everything is right there. Just make sure not to loose the half-moon key for the throttle. I did once : that little thing is important, and dang hard to find
The 3K will fuel to 3000 so you can probably rev 3500 or over, but it will stop pulling around 3000 depending on how you set it up. If you ever want to turn over 3500, get the valve springs for sure.
Dual K20s is offline
post #3 of 25 (permalink) Old 01-11-2008, 04:15 AM
I like beer.
NukleusX's Avatar
Send a message via AIM to NukleusX Send a message via Yahoo to NukleusX
Hey dual, think you can help me do my 3k sometime? errr wait you are a tad bit far away.
Jeremy
94 Ram 2500 4x4 RCLB.
Power: BHAF, 4" exhaust, S300G, 15.5*, 100 plate, 90 hp sticks, 191 dvs, Mike L. trans. more when i remember.
Appearance: 1 pc headlights, HIDs, 4.5" lift, flippy mirrors (up), not so chrome 6" silverline exhaust tip, not so fancy aftermarket wheels
American Club #33
Singles Club #74
TDG Mafia #111
http://www.socaldieseltrucks.com
NukleusX is offline
post #4 of 25 (permalink) Old 01-11-2008, 08:28 PM
just a little bit that would only put me 12hrs away from my tools. I'll pick them up on my why over
post #5 of 25 (permalink) Old 01-15-2008, 02:53 AM Thread Starter
Is there that much of a diffrence in stock to a 3000 GSK? Should I get 4000 and springs. Is it worth the extra money. Can valve springs be done in my garage?
post #6 of 25 (permalink) Old 01-15-2008, 05:25 AM
Definitely worth the extra money. If you don't want to buy the valve springs still get the 4K GSK and don't install the smallest spring in each side and you'll have a 3K.
Valve springs are fairly easy with the right tool http://www.genosgarage.com/prodinfo.asp?number=LC16750
post #7 of 25 (permalink) Old 01-15-2008, 09:08 PM
Hey Duel K20 I am wanting to upgrade to 4k's what is involved ? Do you just pop the smaller springs in and be done with it??
schoust is offline
post #8 of 25 (permalink) Old 01-15-2008, 09:16 PM
Yessir
post #9 of 25 (permalink) Old 01-16-2008, 01:34 AM
post #10 of 25 (permalink) Old 01-21-2008, 02:03 AM Thread Starter
what will a 3000 and a 4000 fuel till? What are safe rpms without springs? Will going to the 4000 help pull my trailer better and make the truck a little faster? If I do get the 4000 can I run around for a couple of weeks till I get more money for springs? Is there anything bad about running the truck at that many rpms. Sorry for so many questions.
