Tourque Converter Lock Up Light - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 19 replies and been viewed 2991 times.
post #1 of 20 (permalink) Old 02-10-2008, 04:03 PM Thread Starter
cumminsdiesel's Avatar
I have a manual lock up switch and I was wondering if you could wire a little light so that when the converter is locked the light is on.
cumminsdiesel is offline
post #2 of 20 (permalink) Old 02-10-2008, 04:13 PM
I would think you could. Just wire it into the circuit to the switch.
post #3 of 20 (permalink) Old 02-10-2008, 04:14 PM
Wait, does locking complete a circuit or break a circuit? It would work if turning it on completes the circuit.
post #4 of 20 (permalink) Old 02-10-2008, 05:49 PM
I know on my 95, locking the TC puts a ground on the wire used to install the switch. If you put a powered LED on it the light will come on when ground is applied. Don't have a wire diagram for yours though, some one should come up with a better answer for you.
cjensen91910 is offline
post #5 of 20 (permalink) Old 02-10-2008, 10:33 PM
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
The switch grounds the circuit. I think a light wired inline before the switch Ts in should light up when ever the tc is locked, but I'm not sure
Dual K20s is offline
post #6 of 20 (permalink) Old 02-11-2008, 01:45 PM
2nd Gen Guru
Mopar1973Man's Avatar
Hmmm... Dual K20 I got a question for ya...
Q: Would this lockup switch work for the gasser series rucks too?
Mom's got a 1996 Dodge 1500 59.L Gasser (Auto). I think it would help her fuel mileage to be able to keep it locked up in 4th...
Mopar1973Man is offline
post #7 of 20 (permalink) Old 02-11-2008, 11:36 PM
I have no idea, but its probably similar :shrug:
post #8 of 20 (permalink) Old 02-11-2008, 11:52 PM Thread Starter
I think that will work. I will try it this weekend and let everyone know. Thanks
post #9 of 20 (permalink) Old 02-11-2008, 11:52 PM
bmoeller's Avatar
Does the 46RE have a lockup clutch?
"Obama = Hoax and Chains"
bmoeller is offline
post #10 of 20 (permalink) Old 02-16-2008, 05:30 AM
BigDodge's Avatar
i have a led in the blank plug next to the od off switch on the dash. when the converter locks the led comes on. it works with the stock lock up from the ecm too. when ever the converter locks up the led comes on. wire the led to a key on power suppley and the ground side to the orange with black on the tranny plug.
96 2500 215 pump,CompR62,DDP3's,suncoast convter,6'lift
96 3500 12v auto,Bullseye CompR62 DDP3's,suncoast converter
95 1500 318 auto "for now"
99 1500 360 auto "for now"
95 1500 Bullseye Powered P-Pumped 24v. [email protected]
BigDodge is offline
