Vacum Pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TheNightmare, this thread has received 3 replies and been viewed 626 times.
post #1 of 4 (permalink) Old 03-03-2008, 03:14 PM Thread Starter
Vacum Pump
Is anyone running a belt driven vacum pump to relieve crank case pressure?
if so how much HP? I know on are gas motor we gained about 35 HP
TheNightmare is offline
post #2 of 4 (permalink) Old 03-03-2008, 04:39 PM
PhilipR's Avatar
There is a gear driven vacuum pump mounted on the motor right in front of the PS pump......
-Phil-
PhilipR is offline
post #3 of 4 (permalink) Old 03-03-2008, 07:26 PM Thread Starter
ok i didnt know but works the same way i'm guessing
post #4 of 4 (permalink) Old 03-03-2008, 07:31 PM
PhilipR's Avatar
It helps with sealing of the rings and such so yes similar to the pump you'd put on a drag motor with low tension rings.
-Phil-
PhilipR is offline
