A cure for the Killer Dowel pin - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jd_craft, this thread has received 18 replies and been viewed 4775 times.
post #1 of 19 (permalink) Old 03-30-2008, 08:52 AM Thread Starter
there is a cure for the killer dowel pin it is made by tst performance it is a longer and an egg shaped washer the washer doesnt allow the pin to back out
jd_craft is offline
post #2 of 19 (permalink) Old 03-30-2008, 03:09 PM
NHRDA Race Director
Twisted Shifter's Avatar
Several sources for the the tab. I know a few guys have made a jig that allows you to run a screw into the case that will do the same thing w/o having to take the cover off ......... that is if the pin is not to far out.
Twisted Shifter is offline
post #3 of 19 (permalink) Old 03-30-2008, 07:04 PM Thread Starter
right that would be cool but if the tab is way out u have no coice but to take the cover off right
jd_craft is offline
post #4 of 19 (permalink) Old 03-31-2008, 02:33 PM
PhilipR's Avatar
You can drill a hole in front and tap it back in and then pin it with the jig....been done a lot.
-Phil-
PhilipR is offline
post #5 of 19 (permalink) Old 03-31-2008, 10:30 PM Thread Starter
i figuered there where tricks to do it without having to take the cover
jd_craft is offline
post #6 of 19 (permalink) Old 01-11-2009, 02:25 AM
Why not just pull the cover? It's not hard, and you can tighten up all of the other bolts that are more than likely loose anyway.
I did my first one a couple of months ago, and it took 5 hours including beer and smoke breaks. Next one will be in two weeks. Should go faster.
Yellow Yota is offline
post #7 of 19 (permalink) Old 01-17-2009, 06:20 AM
4play's Avatar
hard way, easy way, right way, wrong way??? who cares, the axxess hole in cover sounds like a 10-15min fix. i think alot of people could benefit, if jig specs and instructions and pics were added to kdp sticky
4play is offline
post #8 of 19 (permalink) Old 01-21-2009, 11:08 AM
I was quoted 15 hours of labor to do the pin for my truck at a shop.
JSL1990 is offline
post #9 of 19 (permalink) Old 01-21-2009, 01:38 PM
stock is boring
That should include pulling the cam and resealing the gear housing.
'04 LB7 4DR LONG BED 4x4
'02 LB7 REG CAB Utility body 2wd
dragnsled is offline
post #10 of 19 (permalink) Old 01-22-2009, 03:07 AM
Tebow-in'...
mudguppy's Avatar
run away and don't go back.
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline
