CR and 12v - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Fast_and_furious, this thread has received 8 replies and been viewed 1979 times.
post #1 of 9 (permalink) Old 01-12-2009, 02:45 AM Thread Starter
CR and 12v
Alright guys finally want to get another truck to play with. Now what would be better for me if i wanted about 700 hp? Price plays a big part in this so what would be better and more cost efficent (truck included in the build) I'm thinking a 12v but let me get some opinions.
Thanks
03 f-350 cclb srw Oilguard bypass filter sct (doug and spartans tunes) boost,trans,pyro only problems 1 injector and a couple of reflashes runs flawless (knock on wood)
New Toy 97 dodge 2500 4x4 12 valve 4in turbo back exhaust and stock plate FF for now.
Mods to come in the near future
Built Trans, DV, 4k gsk, injectors??, studs
Fast_and_furious is offline
post #2 of 9 (permalink) Old 01-12-2009, 03:34 AM
that depends. Do you want to make the power solely on mechanics or would you like the ability to change up tunes to create different levels of power easily ??
You can do a lot with electronics on a CR that can't be done in a 12V. If you're mechanical skills are that good on a diesel... you could do it in a 12V cheaper
triton is offline
post #3 of 9 (permalink) Old 01-12-2009, 03:43 AM
Official TDG Doctor
hccumminssmoke's Avatar
I would go with a CR simply b/c you don't have to have that power all the time...
and i like how a 24v wasnt an option
Nate
hccumminssmoke is offline
post #4 of 9 (permalink) Old 01-12-2009, 03:57 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
24v's are great daily drivers I just wouldnt own one for a race truck......
ANYTHING a 12v can do a CR can do it ...and probaly do it better.....
I like the 12v because you dont have the fuel restrictions. rpms. can eletronics that you do on a CR.. but the CR you can change your hp setting... 12v if you have it tuned for 500 hp ... guess what your stuck with it unless u change out parts. Me I like BOTH... but the 12v will make you more hp with alot less money then a CR
Jordan
blackcloudCTD95 is offline
post #5 of 9 (permalink) Old 01-12-2009, 08:57 PM
I would go with a CR if I was doing it again. My reason is most 12V have many miles on them and need a little attention with other things such as the front end and drive line. A 700 HP truck is going to require work to the drive line no matter what you built it out of. A CR is a newer body style and usually a nicer interior with better options. Just from the engine stand point you can run bigger turbos with less lag problems on a CR but I don't think you will be able to go 700 on a single without a lag problem unless you use NO2.
later is offline
post #6 of 9 (permalink) Old 01-13-2009, 02:23 AM
Diesel Mafia #67
Any dodge truck with 50k+ on it will need attention dodges eat ball joints and tie rod's....... as for HP....... there are plenty of 250k+ 12v's running in the 11's......
Jordan
post #7 of 9 (permalink) Old 01-13-2009, 02:58 AM Thread Starter
Alright thanks for all the input guys. Still not sure which one i want to get. I'm leaning towards the 12v just because it would be cheaper but on the other hand i do like to be able to switch between power levels. So i really dont know what i'm going to get but we will see.
Thanks
post #8 of 9 (permalink) Old 02-28-2009, 01:25 PM
Send a message via AIM to Morse
Gary Ray has a 97 12 valve for sale right now that he drives to work every day, it looks great, has a good ac, and has run down in the 11's.. It's white, new headlights, aftermarket grille, roll pan, dual stacks, 20' wheels, aggressive tires, etc.. It also has a full billet trans.. It gets mileage in the 20's, and has cut 1.5 60' times.. He's asking 13,000 for it.. He's building a crazy 5,000 pound diesel only class truck right now.. He's on competitiondiesel.com and goes by Wrongway. He owns Southern Diesel Performance in Lakeland, FL.
94 dodge 2500 11.52 1/4 mile
04 Chevy Kodiak 22.5's, custom paint, efi, suncoast, etc
Sold-06 Dodge 2500 2wd standard cab shortbed. 11.17 on street tires. 131.7mph quarter.
http://www.youtube.com/watch?v=yAFAv13J6Zg
69 Camaro with 06 dmax LBZ..
Old trucks = 99 stroke, 03 dmax (13.7's in 03), 3rd gen pro street 12 valve (never made a full pass), 2003 dodge 1500 12 valve 2wd(12.16 on 20's). 05 dodge 3500-13.04
Morse is offline
post #9 of 9 (permalink) Old 02-28-2009, 05:45 PM
Diesel Mafia #67
So he's selling the white truck again........
Jordan
