had a ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 5 replies and been viewed 1006 times.
post #1 of 6 (permalink) Old 01-21-2009, 08:58 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
had a ?
i got a 97 cummins reg cab and long bed its got 205,000 on it since ive had it ive changed the oil and fuel filter reg. and i put the red line fuel addtive and i was wonderin what my fuel milage is?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
The Following User Says Thank You to 97CumminsTurboDiesel For this addition to TDG:
smokin24valve (01-26-2009)
post #2 of 6 (permalink) Old 01-21-2009, 11:29 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
miles driven divided by gallons used to fill tank. If you have 4.10 diffs you would be looking 15-17mpg with 3.55 diffs 19-21 most likely if you keep your foot out of it. I was curious your sig says shave delivery valves? Your not doing that yourself are you? That takes some precise machining.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 6 (permalink) Old 01-22-2009, 12:12 AM Thread Starter
ol naw we got a diesel shop and im lettin him do it. she shaved some on a 92 cummins shaved them .020 and shaved the fuel plate and they took it round the curve and b4 he got back he had to get a new clutch for it
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 6 (permalink) Old 01-25-2009, 02:36 AM
Diesel Outlaw
9512valve's Avatar
dv's wont do much without injectors
dont remember
9512valve is offline
post #5 of 6 (permalink) Old 01-27-2009, 09:19 PM
Diesel Outlaw
96cummins1987's Avatar
A 92 dosn't have a fuel plate unless you converted it to a p pump, it should've had a ve pump on it.
96 Dodge Ram 2500, A/T, 5in stacks, BHAF, And a little bit of timing, fuel, and air.
96cummins1987 is offline
post #6 of 6 (permalink) Old 02-02-2009, 07:47 PM
Diesel Outlaw
9512valve's Avatar
the only thing a ve pump has that you can shave that i no of is the fuel pin
dont remember
