370 injectors - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 13 replies and been viewed 2489 times.
post #1 of 14 (permalink) Old 01-22-2009, 12:50 AM Thread Starter
cumminsdiesel's Avatar
370 injectors
I know there was a post before about these but cant find them. For what they cost what are peoples opinions about them? I know there are better injectors but cant afford to spend to much. Also were is the best deal to get them. Thanks.
cumminsdiesel is offline
post #2 of 14 (permalink) Old 01-22-2009, 01:10 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
SrokeThis seems to have pretty good luck with them. No one else I talk to really likes them though. You can buy them direct from Bosch I think that would be cheapest.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 14 (permalink) Old 01-23-2009, 05:11 AM
Formerly CursedtoFirst45
StrokeThis's Avatar
they're good injectors for the price. Alot of people have rediculous expectations from them. But for me, i spent $300 shipped and will likely dyno over 420 rwhp on saturday. Not too bad of a deal.
Best price is probably gonna be at citydiesel.net
Or used on one of these forums. Im looking to sell mine in a few weeks if you want to wait, im upgrading. I have a thread on Competitiondiesel and Cumminsforum.com
Eric
1994 Dodge Ram 2500
You can take our information, you can try to shut us down, but we're still here, and we're going to be better than ever!!
-John DeereGreen
StrokeThis is offline
post #4 of 14 (permalink) Old 01-23-2009, 02:17 PM
Super Moderator
nevrenufhp's Avatar
I had a set in my old Dodge, and they're a great value. I had pretty much the same truck as you, and adding the 370s really brought the whole package together, except the turbo was a bit under par(stock '35 with a 16cm housing).
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #5 of 14 (permalink) Old 01-23-2009, 02:35 PM
GOS
GOS's Avatar
They are a great affordable injector. Not perfect but they work good. I've got a set here with less than 500 miles on them. We will warranty them as new. The biggest complaint with them is they tend to haze a little at idle because of spray angle. I will let this set go for 300 to your door. Let me know.
Contact 1-800-620-4467
Fax 1-406-222-4926
[email protected]
GOS is offline
post #6 of 14 (permalink) Old 01-27-2009, 12:39 AM Thread Starter
I might have to take you up on that offer. Where would I buy the installation kit and how hard are they to put in?
post #7 of 14 (permalink) Old 01-27-2009, 11:04 PM
Hot Rod Farm Boy
I turned 21
Here is the link for injector swap
Logan
post #8 of 14 (permalink) Old 02-06-2009, 04:31 PM
I ran 370's in my old 12v, and other than the haze, I loved them. I also put a set in my friends 96, and bumping the timing up to 15.5* seemed to really clean up the haze quite a bit. They are a great budget mod, and combine with some other mods and a solid turbo, they are capable of putting out some really nice numbers.
post #9 of 14 (permalink) Old 02-20-2009, 04:14 AM
They are a great injector for the price. I know if the tuning is correct, you can get 800hp out of them.
Rodram2002 is offline
post #10 of 14 (permalink) Old 02-28-2009, 04:09 AM
Ive got a set in my 96 and for the money, they're great. I did notice that they did drop my mileage down some. I havent seen any of the idle haze that everyone else seems to get. Only on cold days (15 degrees and less) I also put them in when I still had an auto, I noticed quite a bit of difference. Then I put my 5speed in and :
1996 2500 4x4, 4500 swap, dana 80 swap, sbc 3250 DD, 370's, 100 plate, 2095 plug, afc mods, boost, pyro, measely stock turbo, 2" leveling kit with 35's on 16x10 wheels, train horns:
Did I mention my truck likes to eat parts? (All within approximately 40,000 miles)
1- dana 70
2- front axle steering joints
2- front hub assemblies
4- ball joints
2- track bars
1- lift pump
1- nv4500 (Guess the lead foot won)
1- steering stabilizer
1- 5th gear cone
1- South Bend OFE
bsplyr500 is offline
Performance Injectors Or Stock Injectors imported_Stroker01 1994-2003 7.3L Power Stroke 8 05-06-2008 04:16 PM
Looking for 24V injectors Cowboy Whats Been Sold 12 01-02-2008 08:36 PM
injectors DBogo 12 Valve Performance 2 12-10-2007 05:49 PM
Injectors 02sprtcumns 5.9L Cummins (1998.5-2002) 10 11-06-2007 07:25 PM
best injectors??? RJPotts 12 Valve Performance 7 04-26-2007 12:18 AM
