anyone try a drop in 13mm P&B? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nevrenufhp, this thread has received 24 replies and been viewed 4106 times.
post #1 of 25 (permalink) Old 01-25-2009, 03:05 PM Thread Starter
Super Moderator
nevrenufhp's Avatar
http://www.pulloff.com/read.php?3,12628
Drop in a set of 13mm plunger & barrelll assemblies, and fine tune it at an injection shop. Make your own Stooopid pump?
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #2 of 25 (permalink) Old 01-26-2009, 12:10 PM
I do not understand how it work?
later is offline
post #3 of 25 (permalink) Old 01-26-2009, 01:24 PM Thread Starter
Super Moderator
nevrenufhp's Avatar
If you get em, take some pix for the rest of us. They would be nice in a DT466 we got at work.
Dale
post #4 of 25 (permalink) Old 03-09-2009, 04:17 PM
ClutchIt97's Avatar
i dont really understand why you would need that when companys like scheid can mod a 12mm pump up to 650-700cc's. and its only like $1,500. yea a stoopid pump is like 750cc but inless your shootin for a 2000hp sled pull truck 700cc is plenty of fuel.
97 12 valve, 5 speed, 700cc scheid injection pump with a 5k gov. spring, scheid 5x.013 injectors, Vulcan Performance boot kit, II 66/74/14, cnc port, balanced crank, o-ringed head, a-1 h-11 head studs, bored .20 over, 7 angle valve job, FASS 200, 21 degrees timing, Titanium retainers, Hardened keepers, Mahle pistons, aem air filter, southbend clutch, lowered 3", and isspro gauges
ClutchIt97 is offline
post #5 of 25 (permalink) Old 03-09-2009, 06:47 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
7inchstack has those.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #6 of 25 (permalink) Old 03-12-2009, 12:32 AM Thread Starter
Super Moderator
nevrenufhp's Avatar
I didn't really price P-pump mods before, I just see used ones online for $3k and up. Just tossing out some ideas. I was thinking of a 13mm pump, but with less rack travel so it burned a little cleaner than a stock pump with big del. valves & holders.
Dale
post #7 of 25 (permalink) Old 03-12-2009, 01:59 PM
ClutchIt97's Avatar
oh, i'd give someone who mods pumps a call before you spend a bunch of money. you can get them to run good
post #8 of 25 (permalink) Old 03-12-2009, 07:30 PM
Of Course
I wouldn't.
That Guy is offline
post #9 of 25 (permalink) Old 03-12-2009, 07:44 PM
ClutchIt97's Avatar
Originally Posted by That Guy View Post
I wouldn't.
what kind of pump do you have?
post #10 of 25 (permalink) Old 03-13-2009, 12:36 AM
Just reading.
later is offline
What would it take for you to drop a friend? Fantom3993 The Parking Lot 31 01-05-2009 09:25 PM
Why did my MPG drop? JeffBrouillette 5.9L Cummins (2003-2007.5) 10 08-15-2007 03:53 PM
2nd gen K&N drop in ash_flat_diesel Whats Been Sold 1 05-14-2007 02:56 AM
2/4 Drop htsht 2003-2007 6.0L Power Stroke 1 08-03-2005 03:15 PM
