Compressor or exhaust housing? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 16 replies and been viewed 2897 times.
post #1 of 17 (permalink) Old 03-18-2009, 02:11 AM Thread Starter
cumminsdiesel's Avatar
I dont have the money right now for a hole new setup and it might be a while. So I need to know, for cooling egts what upgade will work better. A 14 cm exhaust housing or the compressor upgrade to make my stocker a hx35/40?
cumminsdiesel is offline
post #2 of 17 (permalink) Old 03-18-2009, 04:03 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Compared to my setup, I bet your EGT's are mild But what do you do most with your rig? It would be better if you could do both, its still cheaper than a whole new turbo. I think it depends on where you spend the most time in your RPM range. If your always up towards 2500 or more I would get a 16 cm exhaust housing. If you stay in the lower RPMs I would get the compressor.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 17 (permalink) Old 03-18-2009, 04:35 AM Thread Starter
Around 2000 to 2300 rpm. This truck is mostly a tow rig. So spool up time is not a big issue as much as egt control. Mild you say. My pyro goes to 1600 and I could bottom that thing out like its nothing.
post #4 of 17 (permalink) Old 03-18-2009, 04:40 AM Thread Starter
Also do I want the 14 or the 16 cm exhaust housing?
post #5 of 17 (permalink) Old 03-18-2009, 05:40 AM
Formerly CursedtoFirst45
StrokeThis's Avatar
Dont buy an upgraded compressor and install it yourself unless you want to have shards of metal stuck in your engine.
I vote for the exhaust housing. Go with a 16cm. I used an 18.5 for a little bit and liked it but i had more fuel that you do.
Eric
1994 Dodge Ram 2500
You can take our information, you can try to shut us down, but we're still here, and we're going to be better than ever!!
-John DeereGreen
StrokeThis is offline
The Following User Says Thank You to StrokeThis For this addition to TDG:
cumminsdiesel (03-18-2009)
post #6 of 17 (permalink) Old 03-18-2009, 06:35 PM
Hot Rod Farm Boy
I turned 21
Yes I do say mild. Is your probe located pre or post turbo? Mine is post turbo and I can pass 1500 which equates to over 1800 pre turbo reading. I've only done it a couple times, I know it's not good but I'm working on more air right now.
I would get a 16 cm wastegated housing. From what I've been told it will take about another 100-150 RPM to spool.
Eric, why would metal shards end up in the engine? You can buy compressor housings that are machined to fit the body of the turbo right.
Logan
The Following User Says Thank You to cummins power For this addition to TDG:
post #7 of 17 (permalink) Old 03-18-2009, 06:58 PM
StrokeThis's Avatar
Yes, my buddy uses an upgraded compressor side of his hx35 and likes it. But it takes a good deal of balancing that new intake side onto the hx35, and one little mistake can cause agony, since it has to be perfectly balanced. Im not doubting the upgrade, but if it has to be that way, at least have a turbo shop balance it.
Eric
1994 Dodge Ram 2500
-John DeereGreen
post #8 of 17 (permalink) Old 03-18-2009, 11:37 PM Thread Starter
Ok so I was going to get the 16 but bolth the big shops around here said do the 14. They said they dont think I would be happy with the driveability of the 16 at our elevation. SLC, Ut around 5200 feet. More input please as now I am confused as which one to buy.
post #9 of 17 (permalink) Old 03-19-2009, 06:37 PM
Hot Rod Farm Boy
I turned 21
Going from this post, I would go with the 16. It will lower the EGT's more, although I'm not exactly sure how much. Another second or two isn't that long to wait for spool up.
Logan
post #10 of 17 (permalink) Old 03-21-2009, 01:04 AM Thread Starter
Bought 16 today and had it on in little over an hour. Takes a little longer to spool but not bad. When I floor it egts still go right to 1600 degrees. So will see if it helps a little when I pull my trailer.
WTB: stock turbo compressor housing SICKS-O Whats Been Sold 1 01-29-2009 03:41 AM
compressor housing upgrade for 6.0 turbo/? SICKS-O 2003-2007 6.0L Power Stroke 1 12-18-2007 03:48 PM
Upgrade Compressor Housing payne86 5.9L Cummins (1998.5-2002) 1 07-26-2007 03:52 PM
LIPDs Compressor Wheel and Housing Installed. heinzboy 2003-2007 6.0L Power Stroke 158 09-25-2006 09:43 PM
Compressor and housing upgrade jersey250 2003-2007 6.0L Power Stroke 49 08-16-2006 06:33 PM
