boost elbow - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 9 replies and been viewed 1945 times.
post #1 of 10 (permalink) Old 03-23-2009, 01:48 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Exclamation boost elbow
i had a question my truck is stock except the silencer ring and i got a boost elbow comming how much more power will i have,will it be louder?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 10 (permalink) Old 03-23-2009, 03:21 PM
it won't be louder but, you should be able to get more boost from it. The problem is, if you over spool the stock turbo... you could have a grenade on your hands. 38 to 40psi is all the stocker is any good for. Other than that...you're just blowing hot air.
triton is offline
post #3 of 10 (permalink) Old 03-23-2009, 03:51 PM
Official TDG Doctor
hccumminssmoke's Avatar
I have a TST Pre Set 35lbs if your interested in it...
Nate
hccumminssmoke is offline
post #4 of 10 (permalink) Old 03-24-2009, 04:41 PM Thread Starter
Nate
how much you want for it? and what is it exactly? like if im haulen heavy load and i didnt have it it would blow up right? if i did it wouldnt go over 35lbs right?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #5 of 10 (permalink) Old 03-27-2009, 02:24 AM
With the amount of fuel you have, I wouldn't really be concerned with pushing that turbo out of its map. Without the elbow, the wastegate will open at around 18-20psi on your truck venting excess exhaust pressure. With the elbow, the smaller orifice will restrict the boost that is helping the wastegate actuator and keep the wastegate from opening until about 32-35psi.
As for pushing the turbo out of its map by 38-40psi, that depends on what RPM you are turning. an hx35 can be in its map as high as 47psi. But it will only supply enough air at that PR for the truck to be running at about 1100rpm. If you get closer to 3000rpm, it will only push about 22-25psi boost and still stay in its map.
post #6 of 10 (permalink) Old 03-27-2009, 02:59 AM
Official TDG Doctor
you have a PM...
Nate
post #7 of 10 (permalink) Old 03-29-2009, 11:19 PM
bmoeller's Avatar
Just because you have more boost, doesn't always mean you'll be making much more power, if any. Need fuel to do that.
Besides, it isn't boost pressure you should be interested in. It should be air flow. More boost equals more pressure. More pressure means more resistance.
"Obama = Hoax and Chains"
bmoeller is offline
post #8 of 10 (permalink) Old 03-30-2009, 04:39 PM Thread Starter
ol ok
i really dont know bout the afc i think its called does anyone know much bout it?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #9 of 10 (permalink) Old 03-30-2009, 06:51 PM
Tebow-in'...
mudguppy's Avatar
read this thread.
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline
post #10 of 10 (permalink) Old 03-30-2009, 07:15 PM
BUCK2's Avatar
The abolute first thing I wouold do is get some gauges (Boost and Pyro). Then slide your stock plate forward or make you (grind you #100) or something equivalent. There is so much stuff you can do for free that will really make these truck fly, and have controllable EGT's.
After a few mods you will need to upgrade the tranny (if Automatic) or get a new clutch (if manual). I have a blast working on my truck.
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
Boost elbow and 3k gsk ?'s moparcummin 12 Valve Performance 3 07-08-2009 11:11 PM
boost elbow? cummins kid 5.9L Cummins 12 Valve (1994-1998.5) 9 11-26-2007 03:07 AM
Oil in/on Boost Elbow EB.Bldr 2003-2007 6.0L Power Stroke 3 11-13-2007 11:01 PM
boost elbow mock12v 5.9L Cummins 12 Valve (1994-1998.5) 9 08-22-2007 04:08 AM
boost elbow crf450 2003-2007 6.0L Power Stroke 5 08-16-2007 03:21 AM
