12 Valve Individual Runner Intake Plenum Spy Photos! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bobcat698, this thread has received 13 replies and been viewed 10151 times.
post #1 of 14 (permalink) Old 04-05-2009, 05:44 AM Thread Starter
Stopped over at my fabricators place the other day to pick up some ported cylinder heads. I snapped some (crappy cell phone) pics of the intake plenum he has just about finished for my 3.0 Puller!
This thing is a MONSTER compared to what I ran last year, should go nicely with my new HIGH FLOW cylinder head. Cowl modifications are mandatory to fit this sucker...
Bobcat698 is offline
post #2 of 14 (permalink) Old 04-05-2009, 06:56 AM
4cstr's Avatar
Images: 35
Dang Garrett...get that thing polished and shined...and it gonna look awesome.
~Dave~
4cstr is offline
post #3 of 14 (permalink) Old 04-05-2009, 07:18 AM Thread Starter
Probably will only have time to spray bomb it
Thanks!
post #4 of 14 (permalink) Old 04-05-2009, 06:42 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Wow looks good! :
Logan
Do Or Die Garage Experiment
cummins power is offline
post #5 of 14 (permalink) Old 04-05-2009, 10:23 PM
Cummins Junkie
cumminsman315's Avatar
almost like a zz fab!
Bros rig 06 Quad Cab NV4500 3500 Single CP3 Single Turbo-8/14/[email protected] http://www.youtube.com/watch?v=lVRrjK4YeCw
cumminsman315 is offline
post #6 of 14 (permalink) Old 04-06-2009, 03:47 AM
Thats a pretty big plenum. Will the injection lines run under the main part between the individual runners or what? Can you use the stock lines?
post #7 of 14 (permalink) Old 04-06-2009, 05:05 AM
7inchstack's Avatar
that looks nice! but how come its so big? is there an advantage?
RYAN
2007 mega cab 6 speed, Smarty, SB 3600 DD, AFE stage 2, straight pipe, 5.5 inch long arm with coilovers, 37's
1996 dodge 2500 4x4 parts finally coming inSIGPIC][/SIGPIC]
7inchstack is offline
post #8 of 14 (permalink) Old 04-13-2009, 03:23 AM
Diesel Pro
Macktruckdriver's Avatar
Your not putting a bolt on the front part of the manifold to hold it to the head. Id be putting one there. All the ones we have made needed on there it will never seal without it.
Macktruckdriver is offline
post #9 of 14 (permalink) Old 04-16-2009, 07:36 PM Thread Starter
Yep, we are, you'll see the tab in the pictures below.
post #10 of 14 (permalink) Old 04-16-2009, 07:37 PM Thread Starter
New pictures, mocked up on the engine.
pre runner bar.. black06on37s General Ford Truck and Excursion 8 03-02-2008 08:17 AM
Aftermarket manifold/plenum gearhead87 24 Valve Performance 2 01-10-2008 05:18 AM
Intake elbow and valve cover metal Dual K20s 5.9L Cummins 12 Valve (1994-1998.5) 32 09-02-2007 10:42 PM
ATS Housing Intake Runner 6_Myles 1994-2003 7.3L Power Stroke 3 02-19-2007 03:38 PM
plenum intake FSTDZL 5.9L Cummins (2003-2007.5) 4 02-02-2006 10:28 PM
