Clean Engine? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cab9379, this thread has received 4 replies and been viewed 1059 times.
post #1 of 5 (permalink) Old 05-01-2009, 05:51 PM Thread Starter
Clean Engine?
I have a 1997 Dodge 2500 and the engine bay is dirty does anyone have any suggestions on how to clean the dirty ol 12v like what to use and how much? Thank you
cab9379 is offline
post #2 of 5 (permalink) Old 05-01-2009, 06:32 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Keep the pressure washer away from the fuel and electronics, the rest of it will be fine. Hose the rest of it down with 409, Simple Green, or your other parts washer of choice and wipe dry.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 5 (permalink) Old 05-02-2009, 12:47 PM
bmoeller's Avatar
Oil Eater works GREAT on oil and grease. Non-toxic. Kicks simple Green's butt.
http://www.oileater.com/CleanerDegreaser.html
"Obama = Hoax and Chains"
bmoeller is offline
post #4 of 5 (permalink) Old 05-02-2009, 07:06 PM
What are sparkplugs
ICEMAN3005's Avatar
brake cleaner also works great just keep it of the paint though it could eat it.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #5 of 5 (permalink) Old 05-16-2009, 07:05 AM
hereismylife's Avatar
Another thing that works is a hot pressure washer and soap like at a carwash. Also u can go to most recons and they have the hot pressure setup.
95 suburban 2500 4x4 4000 gsk boost,egt,trans gauge
97 6bt, 16.5 *, dynamite 75 (stage 2) , 25 psi ,180 pump, no plate, rack/mack plug , 60 pound springs, 01 47 re ats standalone , 3 disk , 373, arb
hereismylife is offline
Clean at last!!!!!! newtodiesel General Ford Truck and Excursion 15 02-18-2009 10:10 PM
Clean 99 F-250 7.3 Squatch Whats Been Sold 9 01-31-2008 12:38 AM
What should I use to clean my engine? misterex 2003-2007 6.0L Power Stroke 11 08-11-2007 01:12 AM
Clean EGR Turtledude Duramax 2001-2004 (LB7) 19 02-02-2007 06:18 AM
Why you need to clean your PD TDI EGR.....often! TooMuchBoost Euro-Diesels 13 01-29-2007 01:33 PM
