crankshaft - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 9 replies and been viewed 1985 times.
post #1 of 10 (permalink) Old 05-05-2009, 05:04 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Exclamation crankshaft
my timming cover gasket busted ans i was thinkin its the crankshaft vac. i was wonderin where they were located and how to clean them?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 10 (permalink) Old 06-05-2009, 04:28 PM
It may be the killer dowel pin, not the vacume pump.
later is offline
post #3 of 10 (permalink) Old 06-05-2009, 07:13 PM Thread Starter
i fixed the KDP and reset the timmin bc it was off 4 degrees and after did that it started to leak oil and its leakin on the right side of the motor if your in front of it
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 10 (permalink) Old 06-29-2009, 11:11 PM
strawboss's Avatar
It does sound like the KDP. When i got my 12v i thought it was just the gasket, but i soon found out that the dowel pin vibrated out, wedged inbetween the cam gear and busted the timing gear cover. oil was leaking profusely.
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
post #5 of 10 (permalink) Old 06-30-2009, 06:38 PM
TDG Mafia Member #56
Dieselwrencher's Avatar
The vacuum pump is a common leak on these. Also so is the tappet cover, and the oil pressure feed lines and fittings to the Ip and the vacuum pump. Usually the vacuum pump can be resealed to stop the leak.
Putco light bar
Dieselwrencher is offline
post #6 of 10 (permalink) Old 07-03-2009, 02:59 AM Thread Starter
where is the vacuum pump and oil pressure feed lines located?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #7 of 10 (permalink) Old 07-08-2009, 12:25 AM
Behind the IP and VP.
Putco light bar
post #8 of 10 (permalink) Old 07-08-2009, 05:30 AM Thread Starter
ok i appriate it
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #9 of 10 (permalink) Old 08-14-2009, 08:49 PM Thread Starter
i finally got a chance to degrease the bottom end and find out where the oil leak was commin from and its commin from the vp is there a way i would take off the hoses and clean them or is there a point of doin it
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #10 of 10 (permalink) Old 08-18-2009, 12:33 AM
If it is the vacuum pump, you will need to buy a new seal kit and reseal the pump. Check out some of the vendors here or ebay for a reseal kit for them.
Putco light bar
The Following User Says Thank You to Dieselwrencher For this addition to TDG:
97CumminsTurboDiesel (08-21-2009)
Crankshaft Seal cumminsdieselfreak 1994-2003 7.3L Power Stroke 0 03-31-2008 11:13 PM
duramax LBZ crankshaft mtomac Whats Been Sold 0 11-01-2007 03:44 PM
crankshaft seal? turbodave 5.9L Cummins 12 Valve (1994-1998.5) 6 08-30-2007 02:14 AM
crankshaft goodie cumminsmega 5.9L Cummins (1998.5-2002) 1 05-09-2007 02:44 AM
Crankshaft fuzzys69 2003-2007 6.0L Power Stroke 4 01-03-2006 01:08 AM
