'93 Dodge Auto Trans, what can I do with it?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Klutch, this thread has received 2 replies and been viewed 1047 times.
post #1 of 3 (permalink) Old 05-10-2009, 12:23 AM Thread Starter
What can I do that is easy to gain some hp? It's just a beater truck and I only know about Ford diesels and don't have a clue about these mechanical engines. The help is much appreciated.
Klutch is offline
post #2 of 3 (permalink) Old 05-21-2009, 04:56 AM
You can turn the engine up. The problem with that is the stock torque converter Dodge put in the trans will not let to much power threw it.
Your biggest up grade right now is to replace the stock torque converter.
Philip is offline
post #3 of 3 (permalink) Old 05-25-2009, 04:23 PM
Super Moderator
nevrenufhp's Avatar
Converter and gauges first. Then it's ready for fun:
http://www.dodgeram.org/tech/dsl/mor...r/Power_ve.htm
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
need help with 96 auto trans red27 1994-2003 7.3L Power Stroke 1 05-10-2009 02:00 PM
tranny rebuild kits! need help asap tranny is shot...f'in dodge auto trans blksmk 5.9L Cummins 12 Valve (1994-1998.5) 5 12-26-2008 10:55 PM
Which auto trans. sidssm Diesel Conversion 5 11-21-2007 12:27 PM
Dodge 4 speed auto trans. rumble baldeagle 2003-2007 6.0L Power Stroke 2 09-25-2007 03:08 PM
97 auto trans just visiting 1994-2003 7.3L Power Stroke 13 09-25-2006 10:47 AM
