Cleaner 12V - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nevrenufhp, this thread has received 7 replies and been viewed 1717 times.
post #1 of 8 (permalink) Old 06-19-2009, 10:13 PM Thread Starter
Super Moderator
nevrenufhp's Avatar
Cleaner 12V
Just looking for ideas on how to keep a 12V burning clean or cleaner. Here's the theory: A shop calibrated pump with 400cc, on stock 215hp injectors, turbo not really part of the equation. My idea was raising the overflow valve's pressure, and raising the pop off press. in the injectors. Just trying to come up with ideas for a cranked up pump that can pass a snap throttle test, besides just putting the AFC all the way to the back for the test, and not get you pulled over for any smoke related issue.
Dale
or, 06 IH 7400, DT466E, 300hp
My Low Buck fuel rate site:
www.freewebs.com/nevrenufhp
nevrenufhp is offline
post #2 of 8 (permalink) Old 06-21-2009, 07:04 AM
I'm not sure how much effect shimming the overflow would have, but its definitely worth a shot.
Raising the pop-off pressures should help a lot. I have heard of people having good luck with pressures as high as 300 bar.
You may not have to slide the AFC that much, if you set it up with lots of travel you may be able to get away with a very low no-boost setting and still have it very responsive. Something to play with at least
Dual K20s is offline
The Following User Says Thank You to Dual K20s For this addition to TDG:
nevrenufhp (06-30-2009)
post #3 of 8 (permalink) Old 06-21-2009, 03:49 PM
Diesel Mafia #67
blackcloudCTD95's Avatar
Keep em comming., lol. or a simple thing would be not to run dirty sticks or DV's....
Jordan
blackcloudCTD95 is offline
The Following User Says Thank You to blackcloudCTD95 For this addition to TDG:
post #4 of 8 (permalink) Old 06-21-2009, 03:54 PM Thread Starter
Super Moderator
nevrenufhp's Avatar
That was in the first post. A pump shop calibrated pump(no hogged out or cut DVs) and 215 injectors.
Dale
post #5 of 8 (permalink) Old 06-30-2009, 04:28 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Add timing. .02 deposited
Logan
Do Or Die Garage Experiment
cummins power is offline
The Following User Says Thank You to cummins power For this addition to TDG:
post #6 of 8 (permalink) Old 06-30-2009, 06:35 PM
TDG Mafia Member #56
Dieselwrencher's Avatar
A hybrid turbo or small S300 would help a lot. 400cc's of fuel is going to smoke some where in the rpm range and tuning will help but not if you don't add the air to match the fuel.
Putco light bar
Dieselwrencher is offline
The Following User Says Thank You to Dieselwrencher For this addition to TDG:
nevrenufhp (07-01-2009)
post #7 of 8 (permalink) Old 07-03-2009, 03:04 AM
Diesel Mafia #67
I'd say a good tuned AFC, with 191's ddp3's with 400cc pump, and a 62/13 charger with 20* of timing.. its its still alittle hazy bump it up to a 64/13
Jordan
post #8 of 8 (permalink) Old 07-04-2009, 12:14 AM Thread Starter
Super Moderator
nevrenufhp's Avatar
And here you are, Jordan, tryin to give me advice! or maybe trying to set me up for puking out black smoke trails.
That's all fine & dandee, but using 191s with big injectors will make high egt & black fog. The real deal, is planning for a p-pumped DT466 package. With enuf fuel, they can make 600hp on the stock injectors, which from my experience seem to be close to a 180hp(maybe even a 215) 6BT injector. Sure wish I could get the actual specs. I was only trying for a little over 400hp. Finding a turbo for it wont be easy either. My options are basically an S300, around 64mm/16, or a Pro-52 Holset.
Dale
Parts cleaner machine General Ford Truck and Excursion 5 04-26-2009 06:32 PM
Injector Cleaner JLWelding Utility & Farm Tractors 2 02-03-2009 02:53 PM
Air Cleaner and Noise afgunn 6.2L Diesel Engine 2 04-19-2008 05:29 PM
injector cleaner doob51 5.9L Cummins 12 Valve (1994-1998.5) 5 09-21-2007 09:49 AM
Air filter cleaner? FFBellah 2003-2007 6.0L Power Stroke 1 03-29-2007 03:08 AM
