Choked exhaust? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PissPoor, this thread has received 1 replies and been viewed 916 times.
post #1 of 2 (permalink) Old 09-06-2009, 03:45 AM Thread Starter
Choked exhaust?
A week ago my factory tailpipe rusted out just ahead of the rear axle so i went to see my friend at the muffler shop and he bent up and new one and installed it. I noticed the factory one was a mandrell bent so kinks in the bends. I asked my friend how much the kinks would restrict my power and he said I probably wouldn't even notice it but as soon as I left there I could tell something was different. I didn;t have the snap at start form lights and more smoke than before until I reached higher rpms. How much would those kinks hinder my power cause I seemed to be doing good before the new pipe.
1998 Dodge 3500 dually 4X4 with 5.9 12v. 5spd trans with 3.54 gears. Amsoil 6080 filter with outers,stock exhaust with no cat or muffler. Fuel plate full forward with AFC the same. Blocked wastegate and missing silencer ring
PissPoor is offline
post #2 of 2 (permalink) Old 09-06-2009, 04:14 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
It would be like putting your muffler back on. Increased back pressure will make the turbo slower to spool because of the smaller pressure difference before and after the drive turbine. If you want to make sure that's it, pull your exhaust apart somewhere in the middle and see if it goes back like it was before.
Logan
Do Or Die Garage Experiment
cummins power is offline
Dual exhaust or single exhaust imported_7.3FordPower 1994-2003 7.3L Power Stroke 5 11-29-2007 11:58 PM
exhaust mxyoest29 5.9L Cummins (1998.5-2002) 7 08-31-2007 06:26 PM
07-7-7 6.4l - Exhaust Smoke From Front Of Vehicle - Exhaust Odor Inside Vehicle Squatch Ford Oasis requests 0 04-06-2007 12:25 AM
04-9-4 Engine - Exhaust - Turbo-induced Exhaust Moan/drone At 1600-1800 Rpm - 6.0l Bu Squatch Ford Oasis requests 0 03-23-2007 11:59 AM
Exhaust, or no exhaust... that is the question. MaverickUF 2003-2007 6.0L Power Stroke 33 09-11-2005 03:58 PM
