Lookin for a good cam - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigron, this thread has received 15 replies and been viewed 2200 times.
post #1 of 16 (permalink) Old 09-09-2009, 02:46 AM Thread Starter
i need a hot cam that can still be a daily driver but is aggresive when i hook it to the sled anything?
bigron is offline
post #2 of 16 (permalink) Old 09-09-2009, 03:57 AM
I run a helix 2. A lot of guys are switching fletcher's cam though, its even higher lift, but you can still get away with street driving it and not cutting the pistons.
http://dieselproperformance.com/home
http://www.f1diesel.com/helix.html
Greg's max spool is supposed to be pretty good too, and I've heard some pretty mixed things about hamilton's cams. hope this at least points you in a direction, or gets you started.
post #3 of 16 (permalink) Old 09-09-2009, 04:10 AM
Official TDG Doctor
hccumminssmoke's Avatar
helix is sweet, so is haisley's custom grind
Nate
hccumminssmoke is offline
post #4 of 16 (permalink) Old 09-09-2009, 01:00 PM
MeanGreen7.3L's Avatar
Images: 3
haisley's cam are great but good luck getting one any time soon. this is there busy season with all the pulls going on, plus there more pricey.
The smoke don't mean its broke
early 99 7.3L 6 speed 4x4 extended cab 8' bed, 324k, 33x12x17 nitto terra grapplers on 17x12 mazzi hulks, spearco intercooler, Flex-a-liteelectric fan, fluid damper, daul hpop, ARP stud kit, AA code single shot BD 230 hybrid injectors, stealth pump, bowl delete kit, air dog lift pump, F5 DP tuner w/6 tunes, GT 28r ball bearing turbo,custom intake, 4'' turbo back to 6'' Tip
SINGLES CLUB #254
MeanGreen7.3L is offline
post #5 of 16 (permalink) Old 09-09-2009, 10:39 PM Thread Starter
so i wont have any problems driving every day with a helix plus itll answer the calling infront of a sled
bigron is offline
post #6 of 16 (permalink) Old 09-10-2009, 03:27 AM
Yeah, a helix will work just fine. The bolt on cam gear is a nice feature too.
post #7 of 16 (permalink) Old 09-10-2009, 07:49 PM Thread Starter
ok so if i went with a helix, laser cuts, 5 18 inj, then whats the best matchin charger
bigron is offline
post #8 of 16 (permalink) Old 09-10-2009, 09:10 PM Thread Starter
just thought of sumthin maybe 5 18's r a lil much for a daily driver would i b going wrong with 5 15's and a silver bullet
bigron is offline
post #9 of 16 (permalink) Old 09-11-2009, 05:47 AM
I'd stay away from the laser cuts personally. I'd run either an 022 or 024 DV. 5x.018's are huge for the street. Who's pump are you going to run? Charger will depend on what class you want to pull in. 2.6, 2.8 etc... 2.8 and 3.0 class trucks aren't too street friendly.
post #10 of 16 (permalink) Old 09-11-2009, 11:26 AM
JacktheBear3's Avatar
Hamilton Cam's Big Stick is also another great choice for a streetable set up. If you need specs on the cams let me know
JacktheBear3 is offline
lookin to buy a 01 7.3 help !!! 03f250 1994-2003 7.3L Power Stroke 6 09-01-2009 06:03 PM
Lookin to buy!! StrokinOn22s 2003-2007 6.0L Power Stroke 9 01-29-2009 06:26 PM
lookin.... GMguy1234 6.5L Diesel Engine 2 06-07-2007 11:36 PM
lookin for AIC pitjeep Whats Been Sold 1 02-25-2007 05:44 PM
98 12 valve lookin for a good tranny smokeisfun 5.9L Cummins 12 Valve (1994-1998.5) 11 07-31-2006 05:05 PM
