Exhaust Setups - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by UpstateDieselGuy, this thread has received 21 replies and been viewed 6211 times.
post #1 of 22 (permalink) Old 09-09-2009, 10:09 PM Thread Starter
UpstateDieselGuy's Avatar
Question Exhaust Setups
Hey guys, while I was servicing the Dodge on Monday with a buddy of mine we decided to give the exhaust the ol' heave ho. We cut it right before the converter. It honestly sounds so much better than stock. I think it was choked bad. The tailpipe basically fell off the muffler which had a hole starting in the top. Basically I prevented any future issues I am now trying to figure out what I want to do with the exhaust.
Now I need to do something different. I was thinking some 3" pipe work to match the pipe that is there and dumping it in front of the rear wheel. The only other thing that I was contemplating was the 4" tailpipe from NAPA. You can order Dynomax exhaust components individually from NAPA. Here is the Dynomax kit and here is the pipe from NAPA. I could get some 4" pipe there as well.
What have you guys done? Thanks in advance, Chris
SOLD
UpstateDieselGuy is offline
post #2 of 22 (permalink) Old 09-12-2009, 06:40 PM
WHOS NEXT
if you wanna use the factory down pipe go ahead. just get a 3 to 4 inch adapter and run 4 inch pipe back to the back of the cab. then take a 4.5 inch whole saw and cut a hole in the bottom of the bed. get a 90 degree elbow and turn it toward the sky. now the question is which stacks do i go with. do i do a single or duals. and once you decide that then you have to pick the size (5's,6's,7's or 8's)
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #3 of 22 (permalink) Old 09-14-2009, 11:59 AM
PhilipR's Avatar
I will have a 4" DP that has the stock HX-35 adaptor for sale here in a week or two....I am swapping turbos and need a different downpipe.
-Phil-
PhilipR is offline
post #4 of 22 (permalink) Old 09-14-2009, 11:26 PM Thread Starter
Hmm....I will keep that in mind. Chris
SOLD
post #5 of 22 (permalink) Old 09-15-2009, 12:14 AM
PhilipR's Avatar
Just PM me and let me know.....I am ordering my new DP tomorrow and hopefully in a week or so I will be swapping turbos.
-Phil-
PhilipR is offline
post #6 of 22 (permalink) Old 09-16-2009, 07:48 PM
Cummins Junkie
cumminsman315's Avatar
my brother has a 5in down pipe with 6in to the bed and a single 10in stack
Bros rig 06 Quad Cab NV4500 3500 Single CP3 Single Turbo-8/14/[email protected] http://www.youtube.com/watch?v=lVRrjK4YeCw
cumminsman315 is offline
post #7 of 22 (permalink) Old 09-17-2009, 01:54 AM
WHOS NEXT
I wanna see pics. of that.
My truck:
.093 fuel lines
Air Dog 165
custom ground cam
8 x 11 injectors
Pro 52
Polydyn header
4.10 gears
klienn train horns
603hp 1157tq
post #8 of 22 (permalink) Old 09-21-2009, 09:00 PM
Cummins Junkie
i'll try to get them when he comes down in a couple of weeks, i can tell you where to get them
post #9 of 22 (permalink) Old 09-24-2009, 01:48 AM
Cummins Junkie
well he has decided to go with just a 5in downpipe, 6in staight to the 8in tip, but i can still get pics if u want
post #10 of 22 (permalink) Old 09-28-2009, 09:44 PM
SSpeeDEMONSS's Avatar
PICS!
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
Nitrous setups 4x4freak 2003-2007 6.0L Power Stroke 1 05-29-2009 01:46 AM
WMO Filtering - Setups? rrose Bio-Diesel/ULSD/Additives Discussions 6 04-19-2009 07:04 PM
Gauge Setups kwmcdani 2003-2007 6.0 Tuner Forum 22 03-30-2008 07:17 PM
frying oil setups? jizem Bio-Diesel/ULSD/Additives Discussions 16 03-03-2008 03:55 AM
Twin Setups bad_cummins 5.9L Cummins (1998.5-2002) 12 09-14-2006 01:23 PM
