What size Turbo for 500-600hp? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by PhilipR, this thread has received 22 replies and been viewed 16326 times.
post #1 of 23 (permalink) Old 12-03-2009, 04:10 PM Thread Starter
PhilipR's Avatar
I have a question for those more in the know than I. Right now I have an S300 62/65/14 sitting on the bench. It is rebuilt and has a new turbine wheel....ready to roll. With some reading I have done I think this might be a bit to small for my hp goals. I have the opportunity to sell this 62 to a friend that is looking for about 450-500 and I can buy a 64/71/14 for the same price I am selling the 62 for. Would the 64/71 be better for my 600hp DD goal? According to my calcs I will need 550-600hp to crack the 12 second 1/4 mile barrier. I am going to swap out my 370's for some SDX injectors here down but I need to make a decision on the turbo pretty quick so I don't lose out on the upgrade if the 64 will work better. So should I sell my 62 and buy the 64? Sell the 62 and put the money in the bank and save up for a Source compound kit and use my HX up top? I'd rather stay with the single but compounds are cool too.
-Phil-
PhilipR is offline
post #2 of 23 (permalink) Old 12-03-2009, 04:37 PM
WHOS NEXT
The pro52 have made good power. Little slow comin on but they work well. I think a 64 may still be a little slow. Id more consider a 66.
My truck:
1999 Dodge 24 Valve Cummins
P pump conversion with a 180 pump
Pump doesn't have a fuel plate, 4g springs, & full cut dv's, no afc, ect..
.093 fuel lines
Air Dog 165
custom ground cam
mahle pistons with .050 valve reliefs
balanced rotating assembly
8 x 11 injectors
ported head with 60lbs valve springs and 12mm studs
Pro 52
Polydyn header
stage 5 east coast diesel bullit automatic trans.
triple disk dunrite torque converter
4.10 gears
klienn train horns
Nubers with the twins and without header
603hp 1157tq
12.7 quarter mile (then ht3b blew again)
smokin24valve is offline
post #3 of 23 (permalink) Old 12-03-2009, 05:04 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
That particular 64 I think would get you to 500. If you want a single, a Silver Bullet would get you to 650 but will lose a little spoolup on the street. The HX35/HT3B has proven capable of that much power and is relatively cheap. Are you going to spray at all?
Logan
Do Or Die Garage Experiment
cummins power is offline
post #4 of 23 (permalink) Old 12-03-2009, 06:39 PM Thread Starter
PhilipR's Avatar
Not if I don't have to. I have no problem with it if I can have a dependable DD and still get into the 12's. So far I am thinking the HX35/HT3B compounds might be the best option. If so that's fine as I can sell my 62 and just bank it towards a compound kit. The nitrous question though brings up another option though. Can I get away with a smaller charger for DD and still reach my goals?
-Phil-
PhilipR is offline
post #5 of 23 (permalink) Old 12-03-2009, 08:17 PM
Hot Rod Farm Boy
I turned 21
I think you could make it with that 64/71/14, an external wastegate, and some spray.
Logan
post #6 of 23 (permalink) Old 12-03-2009, 09:48 PM Thread Starter
PhilipR's Avatar
But I am worried about DD then and it being dirty and have lag. I think am thinking the HX35/40-Ht3b route is going to be the best of both worlds.
-Phil-
PhilipR is offline
post #7 of 23 (permalink) Old 12-03-2009, 09:58 PM
I've never driven one but I've heard a lot of really good things about the 64/71s. For Example Brad Ponci made 630 or so horsepower with one on his truck, he said it spools better and makes more power than the 66/71 he tried.
IMO the SilverBullet is over-rated. I remember a thread from a while back where one was compared to an A5K and the 5K made more power, more torque, and drove better than the SB.
But like I said I've never driven one personally, I just listen.
Dual K20s is offline
post #8 of 23 (permalink) Old 12-04-2009, 01:05 PM
Hot Rod Farm Boy
I turned 21
The A5K was a 71mm inducer I thought? A 66 vs a 71 isn't exactly a fair comparison.
Logan
post #9 of 23 (permalink) Old 12-04-2009, 01:36 PM
SSpeeDEMONSS's Avatar
yeah, a silver bullet vs a modified K31 isnt quite the same.
ive also heard the 64/71 is better than the 66/71 on a 12v.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #10 of 23 (permalink) Old 12-04-2009, 05:33 PM
If it spools better and makes more power I don't see why a "fair" comparison would matter.
Just a few quotes and a thread to give you something to think about:
http://competitiondiesel.com/forums/...ad.php?t=53878
Originally Posted by jlibert
I have no experience with the Garrett, so I can't help you there.
On my truck, the A5K spooled faster, provided lower egts, a bit higher boost, and made more peak power, as well as more power everywhere under the curve as compared to the silver bullet it replaced.
There is no good reason in my opinion to get the silver bullet unless you're trying to fit into the 2.6 class for pulling.
BUT...........
This was on a common rail-- take it fwiw.
-jp
Originally Posted by BrettWINspeed
From what I've seen on trucks out my way the K31's don't like nitrous, and some of the trucks had a hard time spooling them at the line too, and they end up wiping out there tranny.
Bponci's been saying for a couple of years that a 64/71 is more than you'll ever need, I was one of the few that payed attention to that. He backed up his claims of the 64 being better than a 66 with track times. I was able to dyno a 66/71/14 and then a 64/71/14. The 64 made 29hp more and dropped egt's at least 300* on the dyno runs.
We many not comparing fuji apples to fuji apples here, sometimes a gala comes in a steals the show.
Just something to think about.
turbo size droolinforparts 5.9L Cummins (1998.5-2002) 2 09-21-2009 08:55 PM
KTA Cummins, 600hp, $2000 nevrenufhp Whats Been Sold 3 06-30-2009 12:19 AM
Turbo Size? cummins0797 12 Valve Performance 11 02-22-2007 03:26 PM
What size turbo? FarmboyAC 5.9L Cummins 12 Valve (1994-1998.5) 30 04-11-2006 09:15 PM
a formaula for 600hp? House 5.9L Cummins 12 Valve (1994-1998.5) 5 01-18-2006 06:59 PM
