215hp pumps - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97CumminsTurboDiesel, this thread has received 4 replies and been viewed 1206 times.
post #1 of 5 (permalink) Old 12-08-2009, 04:17 PM Thread Starter
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
215hp pumps
On thoses 215hp pumps. I was wondering if there a way to keep the pump from retarding itself 4 degree's Thanks
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #2 of 5 (permalink) Old 12-08-2009, 04:40 PM
Of Course
Set the rack to 13mm of travel.
That Guy is offline
post #3 of 5 (permalink) Old 12-08-2009, 04:55 PM Thread Starter
how exactly would you do that? Would you add a washer before the diaphragm? Or would you get a new rack plug?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #4 of 5 (permalink) Old 12-08-2009, 05:13 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Slide the fuel plate back.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #5 of 5 (permalink) Old 12-08-2009, 07:46 PM Thread Starter
Right now the plate is moved toward the front of the motor all the way
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
P pumps later 5.9L Cummins 12 Valve (1994-1998.5) 3 02-26-2009 12:57 PM
different ij pumps??? 97idi 7.3L and 6.9 IDI (Pre 1994) 14 02-12-2009 07:48 PM
hard starting IPs, fuel pumps and lift pumps jvbutter 7.3L and 6.9 IDI (Pre 1994) 5 11-08-2007 05:57 AM
CPL 2023 [email protected] (how much $$$) rustyrelic 5.9L Cummins 12 Valve (1994-1998.5) 2 08-05-2007 06:45 AM
Quadzilla stealth R 215hp DPG_Diesel Whats Been Sold 5 11-27-2005 10:35 PM
