How cold is too cold - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Joaquin Suave, this thread has received 10 replies and been viewed 3207 times.
post #1 of 11 (permalink) Old 12-23-2009, 09:33 PM Thread Starter
Joaquin Suave's Avatar
I am about 90% finished with the re-motoring of Casa Azul with a 5.9 from a 1997.5 dodge 2500.
Due to space constraints from the starter, I had to remove the fuel heater. My local "big truck" guru's (I'm on the coast half way between LA & SF) say that unless I'm spending a lot of time in really cold climates...There is no need to worry about the fuel heater. I will still have the air heater and if necessary I'll relocate the fuel heater. Am I OK without a fuel heater????
I mostly travel in Baja & have a saying about ice...
"The only place I want to see ice is in my Margarita!"
Opinions????
Here is a picture of my York air compressor/ dual alternator set-up
http://www.overlandhardware.com/images/Joaquin200.jpg
Arroyo Grande, Alta California
Rancho Oceano, Baja California Norte
_____________________________________
A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of 4x4's, handguns, and tequila.
Joaquin Suave is offline
post #2 of 11 (permalink) Old 12-24-2009, 02:00 AM
Dodgefarmer's Avatar
For the area you live/drive I wouldn't be worried about the lack of a fuel heater. Lots of diesel powered equipment do not have fuel heaters. I doubt that your heater ever comes on unless you get into freezing temps.
singles club # 198
Dodgefarmer is offline
post #3 of 11 (permalink) Old 12-24-2009, 02:43 AM
SSpeeDEMONSS's Avatar
you'll be fine.
that compressor/dual alternator setup is pretty bad arse!
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #4 of 11 (permalink) Old 12-24-2009, 02:55 AM Thread Starter
Thanks guys!!!!
Soon Casa Azul will be on the road with double her former horsepower!
post #5 of 11 (permalink) Old 12-24-2009, 10:56 AM
PhilipR's Avatar
I don't have a fuel heater on my truck here in Northeast Ohio and I don't have any issues. My truck sits out overnights as well. You'll be fine. Just carry some additive with you if you think it's gonna dip below freezing.
-Phil-
PhilipR is offline
post #6 of 11 (permalink) Old 12-28-2009, 05:45 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
I was in Laramie, WY for the last 2 months. My fuel doesn't go through any type of heater since I changed to the Air Dog, and I've started at -22 or somewhere around there many times.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #7 of 11 (permalink) Old 01-28-2010, 05:59 PM
what about the spacer behind the lift pump, which is the mount for the fuel heater. im thinking its 5mm.. by removing this bracket and the heater, will this change the stroke of the plunger on the lift pump or cause premature wear?
MoBe88 is offline
post #8 of 11 (permalink) Old 01-28-2010, 07:23 PM Thread Starter
Very observant!
I milled up an adaptor.
post #9 of 11 (permalink) Old 02-25-2010, 03:01 PM
El Paso, Texas
Wow, that is a nice looking dual alternator/compressor setup.
1999 F250 (2/98), 7.3L, 4x4, ZF6, Warn hubs, bypass coolant filter, bypass oil filter, Isspro gauges, 203t-stat & billet housing, EBPV disconnected, Ford severe duty air filter, zoodad, heater shut off, '08 diff cover, 4" MBRP straight pipe, DP F6 tuner, leveled.
2000 F250, 7.3L, 4x4, Auto, XLT Lariat
1993 Dodge 3/4 ton, 4x4, 5-sp, 5.9L Cummins
1981 Isuzu 4x4 pickup diesel project
lithgow is offline
post #10 of 11 (permalink) Old 03-02-2010, 03:57 AM
I agree. I use the same York compressor on my rock crawler for tools and tires. It makes an unreal amount of air. Do you have more pictures or info on how you mounted it? Build or buy the bracket? The plumbing is a no-brainer for me. I just haven't seen one mounted on that motor yet.
Yellow Yota is offline
Little cold help. Caos56 1994-2003 7.3L Power Stroke 3 03-28-2009 03:14 AM
How cold is too cold for Spartan? MSTR-P 2008-2010 6.4L Engine Tuner Forum 8 03-08-2009 05:46 PM
how cold is to cold to install o rings double-s-diesel 1994-2003 7.3L Power Stroke 10 01-03-2009 02:24 AM
Cold Air Kit????? lilshmo 1994-2003 7.3L Power Stroke 9 02-25-2006 05:08 PM
Smoke on Cold start in cool to cold temps. PSDPlayer 2003-2007 6.0L Power Stroke 16 10-11-2005 04:08 PM
