Cheap performance mods wanted!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Navy_Seabee_CM, this thread has received 3 replies and been viewed 1952 times.
post #1 of 4 (permalink) Old 01-23-2010, 12:20 PM Thread Starter
dagon dagon!
I'm going to buy a freightliner with a 12v 5.9 and I'd like to do all the cheap mods I can to make this thing ugly fast and and neck snapping! then later on dump some money into it. I know of the fuel plate going FF and exhaust mod, intake mod, etc. what else can you do to add power?
97 Ram 3500 2wd dually 12v ff #0 fuel plate, upgraded compressor wheel, nv 4500 rock crusher, 4.10 rear gooseneck & 5th wheel hitch... also has access to underbed repo wheel lift
94 Chevy silverado Blazer 4X4, 350, 700r4, sound system from hell... still drive the dodge mostly
US navy construction & tactical vehicle fleet -Seabee and proud of it!
Navy_Seabee_CM is offline
post #2 of 4 (permalink) Old 01-23-2010, 04:20 PM
Before I would even change the oil in the engine I would Tab the Killer Dowel Pin.
Now with that out of the way start a plan on how you are going to use this truck. You can start with the build up basics and not waste money but it won't be long before you need to make choises.
Gauges
4" Exhaust
4K GSK
60 lbs valve springs
A 0 fuel plate
Work over the AFC
Maybe a rack plug (it depends on the type of injection pump it has)
That should be a good place to start and build from.
later is offline
post #3 of 4 (permalink) Old 01-23-2010, 08:18 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Later pretty much has it covered. Only things I would add are that you will be needing a clutch to hold anything more than the stock fuel plate slid forward, at least my pickup did. Then add a boost elbow so you can get about 30-35 psi of boost, and drill the divider in the exhaust housing on the turbo so it will vent both sides evenly.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #4 of 4 (permalink) Old 01-24-2010, 05:25 AM
Good point.
later is offline
any cheap and easy performance mods? DodgeThis 6.5L Diesel Engine 2 01-19-2009 11:30 PM
cheap mods lilrebeljames 5.9L Cummins (2003-2007.5) 22 07-13-2007 04:24 PM
any cheap mods for OBS trucks? strokedout_07 1994-2003 7.3L Power Stroke 24 06-07-2007 02:38 PM
turbos, injectors, mods for cheap? imported_machine2 5.9L Cummins 12 Valve (1994-1998.5) 2 04-18-2007 02:43 AM
New Ex Cheap Mods? Pegsmi98 1994-2003 7.3L Power Stroke 13 11-04-2006 12:12 PM
