The Air/ Fuel heating circuit question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Joaquin Suave, this thread has received 3 replies and been viewed 1281 times.
post #1 of 4 (permalink) Old 02-01-2010, 06:28 PM Thread Starter
Joaquin Suave's Avatar
For those of you that have swapped a 6BTA into other vehicles...
How do you set up the circuit so that the heaters turn off when the air/ fuel is warm enough?
I have the air temp sensor and the relays...has anyone made a "dummy" EDU?
http://www.overlandhardware.com/images/Joaquin200.jpg
Arroyo Grande, Alta California
Rancho Oceano, Baja California Norte
_____________________________________
A computer lets you make more mistakes faster than any invention in human history - with the possible exceptions of 4x4's, handguns, and tequila.
Joaquin Suave is offline
post #2 of 4 (permalink) Old 02-04-2010, 12:04 AM
Tebow-in'...
mudguppy's Avatar
not sure, but i'm going to face the same issue when i do my swap. what i was planning on is just running the relay off of a momentary toggle switch: when it's cold, hold it on for 5 sec, then crank, and intermitently hold it on for 10 and off for 5 until it idles smooth. seems it's really just to help get 'er started, so i don't think it needs to continue to run much after that. and if it's real cold, she should be plugged in any way to help.
that's my understanding of how you can manually mimic the stock system.... but i'm likely completely wrong.
but, whatever you do, i'll plan on copying (so document and share!!).
Travis
2011 F350 SRW CC/SB 4x4 Lariat 6.7 PSD Dark Pearl Metalic
1974 Bob'd Deuce on 16.00-20 XZLs, locked front and rear, hydro steering, front and rear winches, 5.9CTD/nv4500, hydro-boosted disc brakes
Member since Jul 05, Dually Club Member #63, American Club Member #42, FOSP Member #8
mudguppy is offline
post #3 of 4 (permalink) Old 02-04-2010, 01:45 AM Thread Starter
That was my take on it also.
I'm nearing the end of my re-motor punch list and I've included the necessary wires for the air heater into the loom and am going to stand down on perfecting the heating system until after the shake-down and possibly a month in Baja.
I "rub-elbows" with a few electronic gurus in my line of work, so if need be necessary...I'll call in a few favors.
I also have the advantage of heating the block through an inverter (2KV) from my home bank.
post #4 of 4 (permalink) Old 02-04-2010, 11:14 AM
PhilipR's Avatar
What about a thermo switch? The heaters are supposed to kick on if the temps are under 60*.
-Phil-
PhilipR is offline
short circuit falcon 1994-2003 7.3L Power Stroke 2 08-06-2009 06:27 PM
Fuel Pressure Gauge & IssPro Pyro Circuit Box Cowboy Whats Been Sold 4 03-21-2008 10:15 PM
2004 400 ex pro circuit 03f250 Whats Been Sold 0 02-05-2008 02:38 AM
2004 400 ex pro circuit 03f250 Whats Been Sold 1 02-02-2008 10:18 PM
Short Circuit 95psdF250 The Parking Lot 0 04-19-2006 12:34 AM
