Auto trans mods ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 11 replies and been viewed 2538 times.
post #1 of 12 (permalink) Old 02-12-2010, 05:35 PM Thread Starter
moviking's Avatar
Auto trans mods ?
OK, when I start bumping the power on the dually, what trans mods are needed to handle say 400-450 hp (not sure the trans in a 97 4x4 dually, my tranny guru said he guesses 518 or 618), the TC, pan & shift kit I'm sure, what/whos parts, and approx $$$, got the labor end covered, new to the dodge world, thanks in advance.
EDIT, hey mods, hope this is in the correct room, did'nt see a tranny room, hint, hint
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
The Following User Says Thank You to moviking For this addition to TDG:
Rcannon (02-12-2010)
post #2 of 12 (permalink) Old 02-12-2010, 05:41 PM
Bigrigs's Avatar
A buddy of mine has an 01 2nd gen and had his trans donw with "Goerend"(spelling?, out of Ohio), VB and other parts, he did the upgrade himself at another friend of ours shop....apparently Goerend is the trans guy for Dodge...I'm sure more info will follow shortly here...lots of useful info here at TDG all day long...good luck w/upgrade, those Cummins pull like no other
-SOLD-04 F350 CC DRW 6.0PSD...ARP studded & Elite full delete : DieselSite coolant filter : RED ELC SCT X3 by Innovative & Gearhead : Custom built all Billet 5R110 : Diamond Eye 4" duals : zoodad & ccv mod : guages and more gauges
Bigrigs is offline
The Following User Says Thank You to Bigrigs For this addition to TDG:
moviking (02-12-2010)
post #3 of 12 (permalink) Old 02-12-2010, 05:45 PM Thread Starter
moviking's Avatar
Thanks, you spelled it right, checking it out now.
moviking is offline
post #4 of 12 (permalink) Old 02-12-2010, 05:56 PM
is here and there.
Rcannon's Avatar
Images: 11
Noted!
I'm asking and will let you know.
Rcannon is offline
The Following User Says Thank You to Rcannon For this addition to TDG:
post #5 of 12 (permalink) Old 02-12-2010, 06:15 PM
PhilipR's Avatar
Goerend's in in Iowa and Dave is the man. He makes one of the best converters in the country for our trucks. You have a 47RE trans in your '97. IMO you need a converter, billet input and a VB upgrade. A good rebuild kit from some place like Suncoast would be good as well since it will contain the HD-billet strut brace and billet accumulator piston.....or you just buy a built trans from someone like Goerend.
-Phil-
PhilipR is offline
The Following User Says Thank You to PhilipR For this addition to TDG:
post #6 of 12 (permalink) Old 02-12-2010, 06:52 PM Thread Starter
moviking's Avatar
Thanks for the info, got sit for a bit, sticker shock
moviking is offline
post #7 of 12 (permalink) Old 02-12-2010, 08:30 PM Thread Starter
moviking's Avatar
Turbo Dodge Gang ?
moviking is offline
post #8 of 12 (permalink) Old 02-15-2010, 02:09 AM
Bigrigs's Avatar
Turbo Dodge Gang ?
Bigrigs is offline
post #9 of 12 (permalink) Old 07-14-2010, 03:15 AM
id say for a long lasting trans to just have gorend or suncoast build you one ranging from about 3-6k
bigrigfarmboy is offline
post #10 of 12 (permalink) Old 07-14-2010, 03:16 AM
if your going to be doing alot of drag racing or sled pulling i would do billit input and output shafts
Mods for stock trans shadowgearx 5.9L Cummins 12 Valve (1994-1998.5) 11 01-23-2009 05:18 AM
Which auto trans. sidssm Diesel Conversion 5 11-21-2007 12:27 PM
What trans. mods. do I need Murray689 5.9L Cummins (1998.5-2002) 9 07-25-2007 05:35 AM
97 auto trans just visiting 1994-2003 7.3L Power Stroke 13 09-25-2006 10:47 AM
trans mods crock Supporting Vendors Forum 3 06-16-2006 01:48 PM
