Fair shop rates ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 5 replies and been viewed 1476 times.
post #1 of 6 (permalink) Old 02-17-2010, 06:37 PM Thread Starter
moviking's Avatar
Fair shop rates ?
Was checking out a local diesel shop that mainly does cummins 12 valves, for parts & labor prices for future possible needs, told em what I was going to do to start.....................
KDP fix
100 fuel plate
4k gov springs
60lb valve springs
timing advance
they said they would be happy to help with any/all of it, but would do all above parts & labor for around 1K, I doubt I'll have them do more than the timing advance but does this sound about norm for prices ???
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
post #2 of 6 (permalink) Old 02-17-2010, 09:51 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
75-85 an hour is about average.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 6 (permalink) Old 02-18-2010, 01:13 AM
gone fishin!
for a grand you could do all that stuff your self plus tools plus learn valuable knowledge, then put 4 or 5 hundy toward a nice clutch or tranny rebuild.....
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #4 of 6 (permalink) Old 02-18-2010, 02:23 AM
Hot Rod Farm Boy
I turned 21
Local Cummins shop wanted $495 to put valve springs in! No way I'm doing that, I'll just buy the special tools and do it myself.
Logan
post #5 of 6 (permalink) Old 02-18-2010, 12:56 PM
PhilipR's Avatar
That's probably not to bad for parts and labor but the only special tools needed are for the timing. The valve spring compressor is about $30-$40 but the timing tools are around $200 off eBay. The local shop near me charges $200 to set the timing.....it's up to you on how valuable YOUR time is and how dirty you want to get.
-Phil-
PhilipR is offline
post #6 of 6 (permalink) Old 02-18-2010, 04:10 PM Thread Starter
moviking's Avatar
Thanks all, they will do the timing & kdp fix for 175, gonna let em do that, the rest I'll do.
moviking is offline
2007 mortgage rates - what am I missing? Rcannon The Parking Lot 16 03-14-2009 03:25 AM
Spring rates worktruck 2003-2007 6.0L Power Stroke 3 01-17-2008 09:22 PM
Pics from the fair Bad_Bad_Bubba 2008-2010 6.4L Power Stroke 18 10-02-2006 10:16 PM
