BHAF - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 4 replies and been viewed 5185 times.
post #1 of 5 (permalink) Old 02-22-2010, 10:58 PM Thread Starter
moviking's Avatar
BHAF
OK, picking up the truck tomorrow and got the napa bhaf ordered, am I to guess the stock box just gets tossed, not modded ?
And a pic of how yours looks would be cool, thanks. Don
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
post #2 of 5 (permalink) Old 02-22-2010, 11:13 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Yep. Make sure you get the studs out that hold the stock box on so they don't rub a hole in the filter.
EDIT: I also bought the Outerwears Pre-Filter.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #3 of 5 (permalink) Old 02-22-2010, 11:19 PM Thread Starter
moviking's Avatar
You have a part# for that ?
moviking is offline
post #4 of 5 (permalink) Old 02-22-2010, 11:53 PM
Hot Rod Farm Boy
I turned 21
http://outerwears.com/proddetail.asp?prod=2086
Logan
The Following User Says Thank You to cummins power For this addition to TDG:
moviking (02-22-2010)
post #5 of 5 (permalink) Old 03-02-2010, 04:09 AM
Or, you can go a step farther:
It's an Amsoil filter, but installs in the same space as the BHAF. I believe the Amsoil filter is a #4091.
Yellow Yota is offline
BHAF Cummins Cowboy 5.9L Cummins (1998.5-2002) 12 08-07-2009 03:43 AM
Bhaf Big Gray dodge 5.9L Cummins 12 Valve (1994-1998.5) 30 08-18-2007 04:17 PM
Bhaf? 03cmmns 5.9L Cummins (2003-2007.5) 11 07-13-2007 07:15 PM
bhaf redneckchief 5.9L Cummins (1998.5-2002) 7 06-11-2007 02:16 PM
BHAF for 3rd gen 1911 Guy 5.9L Cummins (2003-2007.5) 5 06-09-2007 08:34 PM
