Grid Heater - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 2 replies and been viewed 1437 times.
post #1 of 3 (permalink) Old 02-24-2010, 11:36 PM Thread Starter
moviking's Avatar
Grid Heater
Looking her all over well today, found the grid heater unhooked and two heavy gauge wires, ends taped up, ohmed the forward lugs it read 1.8, (two lugs forward two back), guessing cause of length and placement of wires mine hooks to the front two, but this morning at 22degs she started fine, any thoughts.
On a good note, installed the 2790 filter and found a 4"turbo back exhaust, (no muffler) and a billet converter allready installed
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
post #2 of 3 (permalink) Old 02-25-2010, 12:15 AM
SSpeeDEMONSS's Avatar
if it starts fine with the grid heater unhooked then leave it.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
moviking (02-25-2010)
post #3 of 3 (permalink) Old 02-25-2010, 03:31 AM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
Take the grid heater out and you will get a little better air flow. They say you can gain up to a half pound of boost.
Logan
Do Or Die Garage Experiment
cummins power is offline
The Following User Says Thank You to cummins power For this addition to TDG:
Grid heater 9512valve 5.9L Cummins 12 Valve (1994-1998.5) 16 02-12-2009 11:39 PM
Grid Heater Prowler97 5.9L Cummins 12 Valve (1994-1998.5) 8 01-28-2009 11:52 PM
Grid Heater zigzkidz 7.3L and 6.9 IDI (Pre 1994) 5 01-08-2008 11:22 PM
Heater grid 67 vert 5.9L Cummins 12 Valve (1994-1998.5) 6 12-01-2007 02:14 AM
grid heater? 02sprtcumns 5.9L Cummins (1998.5-2002) 13 11-09-2007 08:31 PM
