Increased Air flow - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 5 replies and been viewed 1407 times.
post #1 of 6 (permalink) Old 04-03-2010, 09:31 AM Thread Starter
BlowinSmoke's Avatar
Increased Air flow
Unsure where to start. Previous owner uped the fuel pressure on the fuel pump alittle bit and now I'd like to increase the air slightly as well. Would it be better to return the fuel pressure to stock and then go from there?
BlowinSmoke is offline
post #2 of 6 (permalink) Old 04-03-2010, 07:56 PM
PhilipR's Avatar
What psi is it running at?
-Phil-
PhilipR is offline
post #3 of 6 (permalink) Old 04-03-2010, 11:18 PM Thread Starter
Sad part, no guages :/ any other way to find out?
post #4 of 6 (permalink) Old 04-04-2010, 12:20 PM
PhilipR's Avatar
You are going to have to put a gauge on it. I run 45psi with my FASS and has no issues. 12V like 30-50psi depending on your other fueling mods.....but 30-50 is the range to be in.
-Phil-
PhilipR is offline
post #5 of 6 (permalink) Old 04-05-2010, 07:07 PM
SSpeeDEMONSS's Avatar
are you talking about turned the pump up for more power? if so then you need to get at least a pyro and boost gauges to see whats going on.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #6 of 6 (permalink) Old 04-05-2010, 07:09 PM Thread Starter
Sounds good just waiting on the uncles tax return now haha.
Fuel additive for increased MPG? Snow 5.9L Cummins 12 Valve (1994-1998.5) 23 01-19-2010 03:26 PM
Oil in the over flow res littlebigrig6.0 2003-2007 6.0L Power Stroke 7 01-12-2009 07:50 AM
increased power with decreased smoke? dodgedawg 5.9L Cummins 12 Valve (1994-1998.5) 17 08-24-2007 10:09 PM
NHL Headlines Show me the money: NHL salary cap increased to $44M RSS Feeder The Parking Lot 0 06-30-2006 07:01 AM
Air Flow: How to get More ralphinnj 2003-2007 6.0L Power Stroke 11 04-08-2006 10:30 PM
