Injectors & DV's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by moviking, this thread has received 3 replies and been viewed 1842 times.
post #1 of 4 (permalink) Old 04-27-2010, 04:48 AM Thread Starter
moviking's Avatar
Injectors & DV's
Is it necessery or advised to replace the dv's when going to larger injectors ?
I'm guessing yes but sure the gurus here will know, thanks in advance.
'97 3500 dually cc 4x4, bhaf, 4" down pipe to 5" exhaust, 100 plate, boost elbow, 4k gsk, timing bump, 60lb springs. Trans Go shift kit. Billet Converter. Isspro boost, pyro & trans temp gauges.
moviking is offline
post #2 of 4 (permalink) Old 04-27-2010, 06:06 PM
SSpeeDEMONSS's Avatar
you dont have to. though if you're upping injector size for power DVs are usually done as well.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
moviking (04-28-2010)
post #3 of 4 (permalink) Old 04-28-2010, 07:50 PM
Hot Rod Farm Boy
cummins power's Avatar
I turned 21
I ran stock 131 DV's with the 5x.014 injectors for a while until I found these 024's to put in. It works the other way too, I though something was up with my injectors, so I put the stockers back in but still running the 024 DV's.
Logan
Do Or Die Garage Experiment
cummins power is offline
post #4 of 4 (permalink) Old 04-30-2010, 09:59 PM
just ish it
shortbusdriver's Avatar
I would not do them untill you really think you need them
97 Dodge 3500 POS edition
92 Chevy Short Bus 6.2
shortbusdriver is offline
181 DV's moviking Dodge parts wanted 0 04-12-2010 05:07 PM
Dv's mock12v 5.9L Cummins 12 Valve (1994-1998.5) 8 09-29-2009 06:19 AM
Injectors and DV's PhilipR 5.9L Cummins 12 Valve (1994-1998.5) 8 05-06-2009 06:38 PM
Does anyone know anything about the DDP Dv's cummins9185 5.9L Cummins 12 Valve (1994-1998.5) 1 12-06-2007 02:06 AM
L/C DV's blackcloudCTD95 5.9L Cummins 12 Valve (1994-1998.5) 14 11-28-2007 12:57 PM
