1997 7.3 two tuners? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 97flatbed7.3, this thread has received 5 replies and been viewed 1698 times.
post #1 of 6 (permalink) Old 01-19-2011, 08:38 PM Thread Starter
97flatbed7.3
I have a ts 6 position currently installed in my 97 7.3, roommate just gave me his edge evolution from his 97 7.3. Wondering if there is any issues on using both tuners in my rig? Good idea or bad idea? If this makes any difference, has airraid intake, mbrp downpipe, 4 inch custom exhaust, bully dog shift kit, bigger tranny cooler and gauge cluster to moniter tranny temps, why temps and turbo psi. Any advice
97flatbed7.3 is offline
post #2 of 6 (permalink) Old 01-19-2011, 08:47 PM Thread Starter
97flatbed7.3
*egt temps*
post #3 of 6 (permalink) Old 01-20-2011, 04:27 AM
plainredtruck's Avatar
Images: 11
Pic one or the other. You can't use both.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
The Following User Says Thank You to plainredtruck For this addition to TDG:
97flatbed7.3 (01-20-2011)
post #4 of 6 (permalink) Old 01-20-2011, 04:59 AM Thread Starter
97flatbed7.3
Ok, any reason why. Just curious.
Too much pressure and strain on the motor? not enough fuel or air? Stock turbo or tranny won't hold up?
post #5 of 6 (permalink) Old 01-20-2011, 04:46 PM
Supporting Vendor
SeeYa's Avatar
Images: 1
You cannot use a downloader and a chip and get the extra HP you are thinking. Once you put the chip on you are using what's on the chip only. Not both together. Whatever you do, do not download a tune from the evo with the chip installed. You will be out a PCM and or the chip. Maybe both.
Diane
SeeYa is offline
The Following User Says Thank You to SeeYa For this addition to TDG:
post #6 of 6 (permalink) Old 01-20-2011, 06:35 PM Thread Starter
97flatbed7.3
Thank you, I appreciate the help. I was just curious, I have heard of people stacking chips and was curious as to the horsepower gains. Thanks for the help!
Tuners NotaVegetarian 1994-2003 7.3L Chips & Tuners Forum 2 04-28-2008 06:03 PM
Tuners joepa1 LMM Tuner Forum 1 04-26-2008 12:31 PM
tuners? 8yourv8 Supporting Vendors Forum 5 12-05-2007 12:42 PM
Tuners not on the net... 6L strokin 2003-2007 6.0 Tuner Forum 73 10-22-2007 03:42 PM
Used Tuners Galaxie_406 2003-2007 6.0 Tuner Forum 17 10-29-2006 11:18 PM
