99 PSD needs a chip, which? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rich, this thread has received 13 replies and been viewed 1341 times.
post #1 of 14 (permalink) Old 05-02-2006, 07:26 AM Thread Starter
Rich's Avatar
PSD here needs a chip. It's a 99' automatic 4x4. The goal is to have around 330+ RWHP and still good fuel economy. The truck is driven pretty lightly and sits around the posted speed limit +5 MPH. It doesn't pull a load very often and the most it does see is less than 10,000 lbs, generally much less.
.........What'da think he should get? I'm thinking EDGE or maybe ........:shrug:
Rich is offline
post #2 of 14 (permalink) Old 05-02-2006, 03:05 PM
If you want 330 rwhp...skip the edge. With an auto...you are gonna nned a more aggressive chip...I recommend www.dp-tuner.com . You will also probably need Big Oil. From my recent dyno experiences...the 6 speeds dyno close to 325-330 with a chip while the autos dyno close to 295-305. yes, the TC is locked with the autos, BUT there is still more power draining loss in the autos.
Hammer
TheHammer69 is offline
post #3 of 14 (permalink) Old 05-02-2006, 05:34 PM
Tony wildman does some pretty kickazz tuning aswell.
lukecline is offline
post #4 of 14 (permalink) Old 05-02-2006, 07:37 PM
fordt
Can't go wrong with DP Tuner :Thumbup:
post #5 of 14 (permalink) Old 05-03-2006, 01:07 AM
TDG Mafia - Booze Runner
Snowaholic's Avatar
Tadd at ATS or Jody DP
2007 Dodge 3500 MegaCab Laramie CTD 4x4 Patroit Blue Just a bunch of Go fast parts and programing
Snowaholic is offline
post #6 of 14 (permalink) Old 05-03-2006, 01:18 AM Thread Starter
Rich's Avatar
What will the Edge box yeild?
Rich is offline
post #7 of 14 (permalink) Old 06-02-2006, 01:34 AM
If you are looking for an edge for your truck I have one for sale. Let me know
bigwheeling is offline
post #8 of 14 (permalink) Old 06-02-2006, 04:13 AM
4cstr
Rich...the first thing you need to do is look at the PCM. If its an XLE box...you need to ditch it in favor of a PMT or NVK computer. I had an XLE8 pcm...and got a PMT1 pcm from Jody at DP-Tuner and upgraded to one of his chips. The truck has never run so good. To get to 330ish hp...you will need to go with aftermarket sticks and/or turbo. Big oil will help as well. And 99's were notorious for having rotten TC's. If you start hearing a "marbles swooshing around in a coffee can" sound...the TC is going south and its time to look at another.
post #9 of 14 (permalink) Old 06-02-2006, 06:43 AM
dave is right your not going to get 330 out of it with out something else be it a set of injectors, big oil , turbo(maybe), nitrous. but some thing has to be done on top of the chip. to make those #
LIPD is offline
post #10 of 14 (permalink) Old 06-02-2006, 07:11 PM
CSIPSD's Avatar
I saw a Edge do 302 on a recieant dyno, auto, 97. FWIW...
I vote Tadd at ATS or Jody to get close to those #'s
CSIPSD is offline
