95 7.3 Power - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bannon_500, this thread has received 6 replies and been viewed 1033 times.
post #1 of 7 (permalink) Old 11-07-2006, 11:37 PM Thread Starter
bannon_500's Avatar
95 7.3 Power
I have a friend with a 1995 F-350 Powerstroke with a 5-speed. He has a straight pipe, intake, and an edge programmer. He likes the edge but he says he wants more power, who can blame him. He wanted me, since I'm a member, to ask you guys what chip, box, or programmer to get after he sells his edge. He loves smoke as much as I do and, also like me, is on a tight budget. What should he go with?
Jason
Purdue Diesel Club-President
Smokers Club #13
2003 F-250 Reg. cab, long bed, FX4, 6.0 Powerstroke, 6-speed manual
585 HP 1,251 FtLb
SCT tuned by Innovative, 225cc Swamps injectors, S363 Fleece Performance turbo with a billet wheel, Dieselsite billet high volume HPOP, Snow Stage 2 water/meth, ARP Headstuds, RCD EGR delete, Liberator O-ringed heads, Black onyx headgaskets, ITP regulated return, SouthBend 3600 Dual Disc clutch, Airdog 100, CFM intake manifold, Dfuser coolant filter kit, 4" exhaust into 7" stack, AEM intake, Autometer Ultralite boost, pyro, fuel pressure, and air pressure gauge for my Hornblasters.com train horn kit,
Superlift leveling kit w/ 2" lift blocks in the back, 20x10 XD Diesels, 35x13.50x20 Cooper STTs
Kenwood DVD player, 1000 watt Sony Xplod amp with a 12" Bazooka tube and 10" MTX sub
bannon_500 is offline
post #2 of 7 (permalink) Old 11-07-2006, 11:59 PM
Got Diesel's Avatar
Tony Wildman
Kyle
Early 99 F-250SD 7.3 PSD 4x4. Auto, tymar type intake, straight pipe, Six inch stacks, Tony Wildman Four position chip, Street race, 80 Tow, 80 Econo, Extreme. Let the smoke roll. Upgraded torque converter. Autometer Ultralights on the Pillar. Running Cooper Discover STT's.
Got Diesel is offline
post #3 of 7 (permalink) Old 11-08-2006, 12:06 AM
Tony is the best tuner for the first generation PSD's. But your friend needs to know this one little fact. The injectors on that truck limit flow to the point that 75HP or near that is all he will see no matter what chip he is running. With that said, Tony can make a stock injectored truck run better than anybody.
Forever Stroked is offline
post #4 of 7 (permalink) Old 11-08-2006, 12:09 AM
Send a message via AIM to 250stroke Send a message via MSN to 250stroke Send a message via Yahoo to 250stroke
:iagree TW makes some bbad tunes for OBS truck but theres other ppl that make good tunes as well. they ushualy all come on a Custom burnt 6 pos chip that you slide in the back of the PCM. If he wants some real smoke hes gonna need at least a small set of injectors maybe like BDP's Tranny savers or some type of "stage 1" to even smoke as good as a well programed Super duty. If he upgrades the injectors though he'll need at least a pyro and a boost guage. plus a HD clutch. Also a CAC from a SD 7.3 or 6.0 would help and can be set up rather cheap. OBS trucks can make Big power like the superduties but at the low end with alot of stock parts there pretty slugish. I dont know what his budget is but just some suggestions.
2004 F-250 Crew-cab XL 2wd 83000 miles . 4" straight pipe.
10/97 F-250, 180k on the clock, 4.10 gears, Autometer gauges,DIY intake, 3.5" down pipe to 4" straight , ATS 6 position chip, 37" BFG Baja T/A's and 24 bolt Hummer H1 wheels. 1 ton axles and custom suspension.
250stroke is offline
post #5 of 7 (permalink) Old 11-08-2006, 01:19 PM Thread Starter
bannon_500's Avatar
He already has boost, pryo, and tranny temp gauges. Where whould he get the TW and how much is it.
Jason
Smokers Club #13
585 HP 1,251 FtLb
post #6 of 7 (permalink) Old 11-08-2006, 01:51 PM
You can send him a PM Twildman. I will look for the link with his contact info. 1 of the vendors DDP has his chips as well.
RacerX is offline
post #7 of 7 (permalink) Old 12-08-2006, 09:17 PM
Send a message via Yahoo to rosco611
i have friends with the edge programer they all have had good luck. i had a superchips programer and i love the shift patterns. it doesn't matter which chip or tuner is used on the older powerstrokes the stoke injectors max out quickly. my '97 does not smoke other than just a little puff at take off. my next step is a set of stage 1 or 2 injectors.
rosco611 is offline
