Bully Dog Power Junk HELP!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by imported_Big Jake, this thread has received 3 replies and been viewed 555 times.
post #1 of 4 (permalink) Old 06-14-2007, 10:44 PM Thread Starter
So i went to take out my bully dog programmer and the thing wont work!!! usually when u plug it in tho the data link port it comes right on and now there is nothing tyhe screen is blank and the same thing happens when i turn the key ive tried everthing. I have it tuned to the max at 120 hp put i wanna take it out cause i want to get a dp six position chip cause that is what i was told to get if i was to do injectors. Does anyone out there have this programmer and have they had the same problem any way i can get my truck back to stock tune so i can add my new chip???
imported_Big Jake is offline
post #2 of 4 (permalink) Old 06-14-2007, 10:54 PM
You don't have to return it to stock to put in your chip. The chip will override what is programmed into the PCM.
Only downside is you won't have the extreme program in the BD if you want to buy it.
gregrob is offline
post #3 of 4 (permalink) Old 06-15-2007, 01:29 AM
I had a bully dog remove my stock program and then loose connection with the PCM. I sent the PCM to Jody at DP Tuner and he reflashed it to stock and I ordered a chip with 60 & 80 tow and 80 econo and never looked back. If you want your stock program back Jody can most likely help you.
Paul
1997 F350 PSD CC 4X4 AT LWB 4.10S 143,000
35" Toyo MT Tires/ straight pipe/ down pipe/ AFE/ DP Tuner, gauges.
Toys
2006 Vortex 30' TOYHAULER
2005 Yamaha YFZ 450
2005 Yamaha Raptor 50 (kids quad)
DEERHUNTR is offline
post #4 of 4 (permalink) Old 06-15-2007, 01:59 AM
Thats funny, I just posted of this on the 7.3 forum.
Josh
2000 F350 PSD CC 4X4 AT LWB 3.73s 173,000AFE STAGE I, TN.BB, EIS 200CC HYBRIDS F5 DP TUNER 4" TURBO BACK, AEROTURBINE 4040XL, 5" STACKS, ISSPRO GAUGES,PRE AND POST TURBO PYRO, SCANGAUGE.
ELKHUNTR is offline
