How much power? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 19stroker96, this thread has received 30 replies and been viewed 1499 times.
post #1 of 31 (permalink) Old 06-18-2007, 05:47 AM Thread Starter
How much power?
i was wondering i have stacked 100hp superchip and a 80hp micromax 1705 tuner how much power do you think they both add
19stroker96 is offline
post #2 of 31 (permalink) Old 06-18-2007, 02:45 PM
They won't stack. A chip completely overrides a tuner.
Pocket is offline
post #3 of 31 (permalink) Old 06-18-2007, 07:41 PM
Are those both tuners? I think so and if that's the case and you try to "stack" them, the program you put in second would just overwrite the first one. PCM only holds one program at a time.
Only thing you can "stack" on a 7.3 is an ICP mod (like the EDGE EZ or banks) and a chip or programmer.
Otherwise, pringles are the only chips that are good to stack.
gregrob is offline
post #4 of 31 (permalink) Old 06-18-2007, 07:49 PM
MMMMMMMMMMM..........Pringles
Eric
Dually Club Member #53
racehauler is offline
post #5 of 31 (permalink) Old 06-18-2007, 07:49 PM
CSIPSD's Avatar
The superchips "chip" is giving you about (with supporting mods) 290 to the rear wheels... The tuner is giving you nothing as the chip is overriding it.
CSIPSD is offline
post #6 of 31 (permalink) Old 06-18-2007, 08:11 PM
Slow 6.0
wow im gonna have to ditch my programming if a superchip will make more at the wheels then i am now...
2006 F350 XLT 4x4
SICKS-O is offline
post #7 of 31 (permalink) Old 06-18-2007, 08:53 PM
CSIPSD's Avatar
Your numbers are WAY low... I made 351/690 in Colorado with Tadds tuning and a GTP-38r and water/meth. Leaking boost and all...
CSIPSD is offline
post #8 of 31 (permalink) Old 06-18-2007, 08:53 PM
CSIPSD's Avatar
On edit... Looks like you have a OBS, so knock them numbers down to about 260 or so...
CSIPSD is offline
post #9 of 31 (permalink) Old 06-18-2007, 11:39 PM
Slow 6.0
i think u need to stop pulling dyno numbers out of ur ***.
2006 F350 XLT 4x4
SICKS-O is offline
post #10 of 31 (permalink) Old 06-19-2007, 12:03 AM
wow! settle down son. Joe has probably seen more trucks dyno'd than a lot of guys on here.
I can vouch for what he says as well. I've been around the forums and been to several dyno events. A chipped superduty will usually go 300-315 a chipped OBS usually 250-265ish.
Of course dyno numbers are just that, numbers. They can vary by day, truck, and operator.
If you did dyno 280, probably all those "foolish resistors" as you call them screwing with the PCM and the truck doesn't know what to do.
gregrob is offline
