can you remove your chip w/o - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by aldo_45030, this thread has received 4 replies and been viewed 549 times.
post #1 of 5 (permalink) Old 06-22-2007, 06:41 PM Thread Starter
disconnecting the harness from the pcm? Kind of hard to tell the ford dealer i don't have a chip when a Po60? "keep memory alive code " keeps showing.
aldo_45030 is offline
post #2 of 5 (permalink) Old 06-22-2007, 06:52 PM
TDG Mafia Member #73
You can take it off with out unplugging it. I never unlpug my PCM to remove the chip... Just make sure the key is not on.
mattymx is offline
post #3 of 5 (permalink) Old 06-22-2007, 07:39 PM
Make a habit of pulling the keys out of the ignition and putting them in your pocket to pull the chip and you will be just fine. Don't need to disconnect anything.
Eric
Dually Club Member #53
racehauler is offline
post #4 of 5 (permalink) Old 06-22-2007, 09:25 PM
Make sure the key is OUT OF THE IGNITION! not just "off".
gregrob is offline
post #5 of 5 (permalink) Old 06-22-2007, 09:30 PM
CSIPSD's Avatar
Make sure the keys are out... Pull mine all the time... But why worry... What year is your truck, most likly you have no warranty anyway...
CSIPSD is offline
