hay jody????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by strokedout_07, this thread has received 4 replies and been viewed 637 times.
post #1 of 5 (permalink) Old 06-25-2007, 03:58 PM Thread Starter
hay jody?????
hay man how much would a tune cost to run AD's stageII in my OBS i would like to have the (smoke tune and lope idle in one pos and 140 extreme ) just 2 for now till turbo comes around.:thanks:
strokedout_07 is offline
post #2 of 5 (permalink) Old 06-25-2007, 04:00 PM
4cstr
You're better off going to their webpage and seeing the prices that are advertised there. They are in the process of moving and won't be able to see this for at least a couple of weeks.
www.dp-tuner.com
post #3 of 5 (permalink) Old 06-25-2007, 04:01 PM
KT Performance's Avatar
Send a PM to Diane ("SeeYa"), she can help you out.
KT Performance is offline
post #4 of 5 (permalink) Old 06-25-2007, 04:18 PM
In case they don't tell you........You better get at least one tow tune or something like that for when the cops are after you for blowing smoke all the time. Also so you can actually pull a trailer without EGT going through the roof.
Eric
Dually Club Member #53
racehauler is offline
post #5 of 5 (permalink) Old 06-27-2007, 08:55 PM Thread Starter
yeah good point race hauler but ok ill see what the web says and then if i order one ill pm seeya
