Stacking with the Dp-Tuner?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dotson90, this thread has received 5 replies and been viewed 978 times.
post #1 of 6 (permalink) Old 07-01-2007, 07:30 PM Thread Starter
Cummin' get ya some!
Could i keep my edge juice w/attitude for gauges and get the dp tuner?? a buddy of mine has a d-max and had a custom tune and a juice w/attitude for gauges didnt really help performance if he turned it up but i would sure smoke
2001 Ford F-250 4X4 Extended Cab Lariat 7.3L Auto. EDGE EZ, Diablo Predator Programmer, 10k Mod, Foil Delete, ZooDad Mod, 4-in. Straight Custom Exhaust, 2 in. Blocks in front, 35 in. Pro-Comp Xtreme A/T, Rhino Lining in Bed, Limo Tint all the way around and thats about all....for now!
2000 VW Jetta TDI Manual 5 Spd. Bone Stock and averaging 45 mpg!
dotson90 is offline
post #2 of 6 (permalink) Old 07-01-2007, 08:23 PM
circle5's Avatar
I think you can use the gauges, but you can't stack the programs. I'm not positive but someone who is will stop in
circle5 is offline
post #3 of 6 (permalink) Old 07-03-2007, 07:28 AM
When I talk to Elite they said it would work fine it would just make there tunes alittle hotter but not much.(until u max the HPOP and injectors). This was for my buddies 01.
Scott
SmokingIDI_7.3L is offline
post #4 of 6 (permalink) Old 07-03-2007, 09:31 PM
You CAN NOT stack the EDGE J/A with a Dp-Tuner, not possible!
They both put their own program on the PCM, and there's only room for one!
What you CAN "stack" is the Edge Evolution because it is a simple ICP mod.
gregrob is offline
post #5 of 6 (permalink) Old 07-05-2007, 07:22 PM Thread Starter
no sir the evolution is a PROGRAMMER the others are icp mods my juice has no connections to the pcm its hooked to the icp and several sensors under the hood for the attitude monitor which is the only thing in the cab, your referring to the EZ which is one plug to the icp the juice has no programs otherwise i could do my shifting and what not right?? :shrug:
dotson90 is offline
post #6 of 6 (permalink) Old 07-16-2007, 01:11 PM
that is right the juice does not reprogram the ecm the evolution does it is a tuner. you can stack a tuner and the juice but the juice is basicaly just gauges then.
