DP Install question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by todd740, this thread has received 4 replies and been viewed 467 times.
post #1 of 5 (permalink) Old 07-12-2007, 09:50 PM Thread Starter
DP Install question
I just ordered my DP tuner yesterday and I had a question relating to keeping the keys out of the ign during the install. Often when my keys are out I still get to door chime, if I jiggle the wire bundle that runs to the key cylinder or tap on the cylinder, the chime will stop. Will this cause a problem when I go to install my chip?
todd740 is offline
post #2 of 5 (permalink) Old 07-12-2007, 09:59 PM
CSIPSD's Avatar
You might want to unhook the batterys just for good mesure...
CSIPSD is offline
post #3 of 5 (permalink) Old 07-13-2007, 03:43 AM
Yah Do It!!!
Dont take any chances, I fried my pcm and my chip with the key in and on, long story, and I am not alone. $$$$
Josh
2000 F350 PSD CC 4X4 AT LWB 3.73s 173,000AFE STAGE I, TN.BB, EIS 200CC HYBRIDS F5 DP TUNER 4" TURBO BACK, AEROTURBINE 4040XL, 5" STACKS, ISSPRO GAUGES,PRE AND POST TURBO PYRO, SCANGAUGE.
ELKHUNTR is offline
post #4 of 5 (permalink) Old 07-13-2007, 11:55 AM Thread Starter
Is it the unhooking and re-attaching the plug in the engine bay that is the step that will cause problems?
todd740 is offline
post #5 of 5 (permalink) Old 07-13-2007, 01:14 PM
If you have some kind of power still on and you do any kind of plugging or unplugging of the PCM your at risk of frying things.When you mess with the chip ALWAYS keep your keys in your pocket and in your case disconnect the batteries too be safe.I will get very expensive frying the PCM and possibly the chip.
boggerr is offline
