idi turbo EGT's and boost ?'s - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDITurboPuller, this thread has received 7 replies and been viewed 1474 times.
post #1 of 8 (permalink) Old 07-18-2007, 12:55 AM Thread Starter
I have a 1994 F-350 with a 7.3 idi turbo (Not A Powestroke) and would like to know what a acceptable range of EGT's are on that engine. I need to get a pyrometer first, but I am going to turn up my injection pump and just want to know proper EGT's before proceeding. Also I'm looking for suggestions on getting more boost. Any ideas or secrets??
IDITurboPuller is offline
post #2 of 8 (permalink) Old 07-18-2007, 01:00 AM
1250 max, sustained pre-turbo
adjust the wastegate for boost, 13psi max
gregrob is offline
post #3 of 8 (permalink) Old 07-18-2007, 01:03 AM
SmokingIDI_7.3L is offline
post #4 of 8 (permalink) Old 07-18-2007, 02:14 AM Thread Starter
Not sure what he meant by "sustained pre-turbo":shrug:
post #5 of 8 (permalink) Old 07-18-2007, 04:30 AM
that means the max egt you can run is 1250 sustained which means for an extended period of time.
if the thermocouple is mounted BEFORE the turbo.
gregrob is offline
post #6 of 8 (permalink) Old 07-19-2007, 12:25 AM Thread Starter
What is a thermocouple and how can I tell if its before or after the turbo?
post #7 of 8 (permalink) Old 07-19-2007, 12:39 AM
it will be a prob with a steel braided wire off of it and it is probly pre-turbo in one of the exhaust manafolds(most likely pass. side.) if its post-turbo it will be in the down pipe(the pipe comming off the turbo. hope this helps
Scott
I just reread ur post and see that u want to put one in. put it in the pass side manifold, at the back of it. the thermocoupler is the thing that tells how hot the egt's are. it will come with ur egt gauge.(its not on the truck right now)
post #8 of 8 (permalink) Old 07-19-2007, 01:41 AM Thread Starter
I put a little thought into it and figured it out and realized I sounded like a idiot asking that, I just never heard it called that before.
