dp tuner 140 tune - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sidssm, this thread has received 9 replies and been viewed 1357 times.
post #1 of 10 (permalink) Old 07-20-2007, 02:56 AM Thread Starter
sidssm's Avatar
dp tuner 140 tune
i have a 1999 f250 psd auto wicked wheel 1.0 housing and i will be putting on cai and straight through exhaust can i run the 140 tune and lope idle safely(without destroying anything) from what i gather the dp tuner is the way to go.
sidssm is offline
post #2 of 10 (permalink) Old 07-20-2007, 02:59 AM
Yes you can run the 140 tune, but can you take advantage of every bit of that power???? Doubt it. That tune calls for a lot of oil, and the stock HPOP probably won't keep up. You'll know for sure when it feels like it's falling on its face at high rpm's.
Also watch the EGT's, the 140 tune can make temps climb. By the way, do you have gauges?
Pocket is offline
post #3 of 10 (permalink) Old 07-20-2007, 04:00 AM
TDG Singles Club #112
cummins_cowboy's Avatar
What Did I DO?
Send a message via Yahoo to cummins_cowboy
I was just on the phone with Jody earlier today, talking to him about tunes for my 99, he recommended the 120 hp tune for me. (mine is an early 99 though, smaller EVERYTHING) Just what he told me, just my .02
Early 99 F-350 4wd SC LB Lariat 7.3/ZF-6
S&B Air Box,4in dp, 5 inch straight pipe
DP F5 with hi idle, 60 tow, 80 econo, and 120 race
SS HPX line, ITP Overboost Annihilator, CCV mod
1995 Pontiac Formula Firebird LT1/6spd
1977 Chevrolet K-20 4spd
1973 Peterbilt 359 Big Cam/ 13spd
1989 Peterbilt 379 Long Hood B model/13spd 22' Mid-America Combo Box
1985 Peterbilt 359 Big Cam / 13spd
cummins_cowboy is offline
post #4 of 10 (permalink) Old 07-20-2007, 10:32 PM Thread Starter
sidssm's Avatar
i have the gauges on the way pyro, trans, boost
sidssm is offline
post #5 of 10 (permalink) Old 07-20-2007, 10:33 PM Thread Starter
sidssm's Avatar
what is the difference between a early 99 and a later 99
sidssm is offline
post #6 of 10 (permalink) Old 07-20-2007, 10:54 PM
Early 99 have 120cc injectors vs 140cc. They also have a 15 deg. HPOP vs. the 17 deg. in the late 99 and up. It has a different turbo but not necessarily worse. The sheet metal intakes are smaller diameter like the OBS trucks have (not sure on the size 2" maybe) and the late 99 and up have 3" intakes
The biggest difference as far as power goes comes from the injectors.
Eric
Dually Club Member #53
racehauler is offline
post #7 of 10 (permalink) Old 07-20-2007, 10:55 PM
Slow 6.0
hpop injectors computer better compressor wheel idm etc etc etc
2006 F350 XLT 4x4
SICKS-O is offline
post #8 of 10 (permalink) Old 07-20-2007, 11:19 PM Thread Starter
sidssm's Avatar
how can i tell which one i have is there a production date or vin number on my valve cover it is rated at 250 hp does that tell anything thanks
sidssm is offline
post #9 of 10 (permalink) Old 07-21-2007, 03:15 AM
The late 99 has 2 big relays on top of the engine on the passenger side and the early 99 only has 1. The reason for the difference is that the late 99 has an Intake Air Heater (IAH) which is powered by one of the relay's. The early 99 does not have an IAH so it only has the glow plug relay (GPR)
You can also look for the IAH in the intake spyder. Joe has a good pic of it, I will see if I can find it.
Found it.
Link to pic
Eric
post #10 of 10 (permalink) Old 07-23-2007, 06:39 PM
What Did I DO?
Or you can look at the VIN sticker on your door for the build date. Mine is 7-12-98, signifying an early 99 model. I don't remember the exact cutoff date on them though. :grd
