dp tuner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WHITEPOWERstrok, this thread has received 4 replies and been viewed 600 times.
post #1 of 5 (permalink) Old 08-08-2007, 04:23 AM Thread Starter
dp tuner
my friend's 7.3 is a dog when tryin to pull his airboat, or really any trailer... from what everyone says, dp is the way to go. where should i get it from, and are they custom tuned like how DJ tuned my SCT i used to have on my ford?
2003 Ford F350 FX4 6.0L - 2007 Front Clip
16" Custom Lift/Dual Reservoir shocks/Traction Bars
42x15R20 Swamper SX2's/20x12 black XD Rockstars
Road Armor Stealth front-rear Bumpers/AMP Powersteps
Recon Smoked LED everything/Smoked LED 1 pc Headlights
SCT Xcal3 Tuned by DJ/Josh's 190cc injectors/DJ's Fuel Intensifier
ARP headstuds/Dfuser EGR delete/7" black stack
94 2500 12v - Reg cab 4x4
Wicked Diesel S300-S400 twins/Airdog Fuel pump
DDP fireringed head/DDP injectors/ARP headstuds
ATS manifold/MBRP exhaust/AFE filter
Garmon "whoop azz" trans, and lots more
WHITEPOWERstrok is offline
post #2 of 5 (permalink) Old 08-08-2007, 04:26 AM
GO to DP Tuner and give Jody a call, then wait for the perma grin after you get it installed:Thumbup:
Paul
1997 F350 PSD CC 4X4 AT LWB 4.10S 143,000
35" Toyo MT Tires/ straight pipe/ down pipe/ AFE/ DP Tuner, gauges.
Toys
2006 Vortex 30' TOYHAULER
2005 Yamaha YFZ 450
2005 Yamaha Raptor 50 (kids quad)
DEERHUNTR is offline
post #3 of 5 (permalink) Old 08-08-2007, 04:26 AM
Slow 6.0
well is it a dog because its stock or is it not runnign right? i agree stock leaves a lot to be desired but if theres issues with the trucks drivability id fix whatever is wrong before throwing a chip at it.
2006 F350 XLT 4x4
SICKS-O is offline
post #4 of 5 (permalink) Old 08-08-2007, 04:27 AM
Hotsauce2138
Send a message via AIM to HotSauce2138 Send a message via MSN to HotSauce2138
i think they are just basic tunes unless he has some serious upgrades. but his sounds stock, get an exhaust and intake and then get the F5 chip and his truck will have no problem towing that trailer.
SAM
Late 99 F-250 CC SWB Lariat 6 sp. 4x4 - the mods= Garrett GTP38R Turbo, DDP Stage 2 Single Shot Injectors. Shimmed Regulator, CCV Reroute and HX Hose from Dfuser, 4" turbo back straight pipe to GR 5" stack kit w/ 7"mitre cut stacks DPPPOWER.COM, AFE Stage 2 Intake w/ PG7, DP Tuner F5 Chip, 18K Mod Dfuser, SouthBend Clutch, Pro Pods quad a-pillar pod, Autometer Ultra-Lite Series Guages ( EGT, Boost 0-35, Trans Temp, Fuel Pressure and Engine oil temp.), Pro tech cab guard, WELD Sidewinders. Road Armor's!!! Custom Pro Tech toolbox/stack cover, , Sirius Sat. Radio, BD Exhaust Brake, 06 Towing Mirrors w/ LED blinkers and heated
:93C_peelo
My Gallery: http://fordtruckworld.tenmagazines.c...y.asp?id=18074
Singles Club Member #52
Can You Keep Up??
Because I'm trying to. lol
HotSauce2138 is offline
post #5 of 5 (permalink) Old 08-08-2007, 05:18 PM Thread Starter
he's got a 5" turbo back straight pipe and an AFE stage 2
