A ? about DP tuner - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TJJR, this thread has received 7 replies and been viewed 851 times.
post #1 of 8 (permalink) Old 08-14-2007, 01:21 AM Thread Starter
A ? about DP tuner
Everyone knows that they rock! No question about that. My question is about how the F-5 switch is hooked up to the PCM. Has anyone had any problems with the wire pulling or slipping out? How do you prevent or fix this? I think someone said duct tape. Does anyone have any issues with it falling out?
Early 2003 F350 6.0 4x4 crew cab
190cc, Innovative Tunes,Stage2 VGT-Hybrid from ID, Airdog 2, FULL egr delete, headstuds, and some other go fast stuff!
TJJR is offline
post #2 of 8 (permalink) Old 08-14-2007, 02:08 AM
CSIPSD's Avatar
The switch or the chip? I dont even tape mine in...
CSIPSD is offline
post #3 of 8 (permalink) Old 08-14-2007, 08:19 PM Thread Starter
I'm sorry. I meant the chip. This is for my fathers truck. He had another chip that was loosing contact with the computer and causing his truck to shut off randomly. The chip was duct taped in and still loosing contact. Now he is wanting to upgrade and I told him that everyone with a 7.3liter raves about DP-tuner.
TJJR is offline
post #4 of 8 (permalink) Old 08-14-2007, 09:03 PM
CSIPSD's Avatar
Like I said... I dont tape mine in as I am swapping chips all the time... No issues in 100k...
CSIPSD is offline
post #5 of 8 (permalink) Old 08-15-2007, 02:35 PM
the contacts might have not been clean enough
96 F350 crew cab long bed. DIY green filter intake 7 inch stacks. stock height .275,000 and still truckin
96 stroker is offline
post #6 of 8 (permalink) Old 12-23-2007, 01:04 PM
dieselman723's Avatar
Don't know if your still having problems with your fathers truck or not. But my truck will shut off randomly every now and then too. Thought it was the chips connection so I took it out and the truck still did it. I've yet to figure out what the hell it is.
dieselman723 is offline
post #7 of 8 (permalink) Old 12-23-2007, 01:20 PM
Paul Ray's Avatar
when i installed mine i just slide it back into the black plastic sleeve and that holds the chip in firmly and it cant back out.
Paul Ray is offline
post #8 of 8 (permalink) Old 12-24-2007, 04:20 PM
if you guys are running the f5 they have had few problems with the controller switch, if this is the case and knowing how great jody and diane at dp tuner they will replace it, just call and share the problem or you can bend a pin slightly on the back sid eof the switch housing and it will snug up the connection. Just a thought, good luck
2000 F250 Crew Cab, Short Bed, Oxford White, 305x70x16 BFG A/T K/O, 16x10 Alum. Wheels, XM and other stereo goodies, Autometer Ultralite Guages (TRANS, PYRO, BOOST) 3.73's, Dp-Tuner F5 w/ 60tow, 80tow, 80econo, 100, 120, 140 :Thumbup: , AFE Stage II, 4" SS Sraight Pipe, B & W Turnover and Tow n Stow receiver hitch, 08' Tailgate (thanx to Blowin' Smoke) rhino-liner, 05' Grille, newer drink holder, Kobalt full width chest, boost fooler
SOLD 07/08
1989 Dodge W250 Regular Cab (purchased from original owner 10/31/09)
AT, A/C
120,00 miles
needs some goodies
HIGH MILEAGE ELITE is offline
