tow setting on DP tuners - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blk99, this thread has received 7 replies and been viewed 1199 times.
post #1 of 8 (permalink) Old 09-17-2007, 10:38 PM Thread Starter
Mafia Member #93
blk99's Avatar
Is it really necessary to get the 40 heavy tow when towing a 15,000# 5er cause I can tow it in ALMOST any terrain with the EVO. on the 80hp setting with reasonable EGTs(1150-1250)? I am trying to keep cost down for know so I would like to get 60, 80 eco, 140 agg. for the time being. With that said can the chip have tunes added later like maybe the 120 or would I have to sell that chip and get one with the settings I would want?
blk99 is offline
post #2 of 8 (permalink) Old 09-17-2007, 10:55 PM
4cstr
If you get the F5...you can send it back at anytime and have Jody had more tunes to it.
I tow with the 40hp tow burn...and I can almost promise you that it will perform as good...if not better...than the Evo 80hp tune.
With my 40hp tune...I can walk a 7% grade coming out of Rapid City toward Wall at 65mph...no smoke...EGT's right around 1100 degrees...and pass anything that is pulling a trailer.
post #3 of 8 (permalink) Old 09-17-2007, 11:20 PM Thread Starter
Mafia Member #93
blk99's Avatar
So would you say instead of the 60 go with the 40, 80eco., and 140 agg.(I have to have the smoke tune!)
About the only thing I tow is the 5er but sometimes a dump trailer or something.
BTW you have alot more mods than I do so that makes a difference!
blk99 is offline
post #4 of 8 (permalink) Old 09-17-2007, 11:20 PM
CSIPSD's Avatar
Just because Evo says its a 80hp dont mean squat... a 40hp from anyone else will walk away from the edge...
CSIPSD is offline
post #5 of 8 (permalink) Old 09-17-2007, 11:51 PM
I run custom tunes from Jody based off the 40 tow, 80 econo, and 140 extreme (I wouldn't call my 40 tow tune a 40hp setting, more like 80 now). Most of the time I'll tow in the 80 setting, and flip to 40 only when EGT's start climbing. That rarely happens though, and only recently I actually needed it due to leaking up-pipes. But my thoughts have always been that I can have a good fail-safe tow tune for those "just in case" times. Before leaking up-pipes, Eisenhower pass was a piece of cake in the 80 tune with a trailer in tow.
Pocket is offline
post #6 of 8 (permalink) Old 09-17-2007, 11:56 PM Thread Starter
Mafia Member #93
blk99's Avatar
I think I have a leaking up pipe also. I am trying to save up to get the BWD bellowed ones!
blk99 is offline
post #7 of 8 (permalink) Old 09-20-2007, 11:21 PM
Ford 6.4 it's just cooler
trapit's Avatar
i tow 12K with the 80hp tune...steep grades... I have to keep out of it, but firm throttle is just fine EGT wise
Paul Alewine
2008 F-250 King Ranch AFE Stage II MBRP Duals and Spartan 310 Tuned
2" BDS Lift on 35" Toyo M/T's
Singles Club #74
American Club #13
trapit is offline
post #8 of 8 (permalink) Old 09-21-2007, 12:59 AM
midwestoffroad's Avatar
FedEx is picing mine up tommorow ,, plan is 80 Tow, 80 ECON and 120
I dont tow much more than a car trailer with a car or truck on it... some day io may mant to pull a travel tailer but suppose i can deal with it then.
midwestoffroad is offline
