ts....tranny killer?????? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99_stroker, this thread has received 20 replies and been viewed 1568 times.
post #1 of 21 (permalink) Old 09-21-2007, 02:34 PM
99_stroker
if i put a ts 6 position in my truck and gave tho occasional smoke show but ran her nice and easy most of the time would it tear up my auto tranny?.... or should i install a tranny cooler with it...i dont want to spend the extra dollar if i dont have to:smoke
post #2 of 21 (permalink) Old 09-24-2007, 12:59 PM
You can burn up the transmission running stock if you drive it wrong. Adding power can increase the chances of premature failure unless you take it easy and drive normal. The problem is it's hard to resist the added power, so it's going to be up to your right foot.
There are mods you can do to help prolong the life, such as a new valve body as well as the bigger cooler.
Pocket is offline
post #3 of 21 (permalink) Old 09-24-2007, 06:41 PM
CSIPSD's Avatar
If you cant afford to fix it... Dont mod it... Short and sweet... And TS tunes are some of the worse...
CSIPSD is offline
post #4 of 21 (permalink) Old 09-24-2007, 06:50 PM
Mafia Member #93
blk99's Avatar
:iagree
But if you are gonna go with a multi-position chip I would recommend DP tuner, I dont have mine yet but one of my buddies has one and it is incredible!
blk99 is offline
post #5 of 21 (permalink) Old 09-27-2007, 01:49 PM
You can't argue with that logic. Some chips will bind the tranny from too much pressure. Most often at WOT. Shift kits and Valve bodys are a way to have it both ways. Any mechanical changes like these to the tranny won't change anything else---chip or not. No side effects. :Thumbup:
RacerX is offline
post #6 of 21 (permalink) Old 10-01-2007, 08:08 PM
Steel's Avatar
Exclamation
DON'T go with TS, i hated it, the program is terrible on the shifting, clunking, and dropping into gear, absolutley terrible, i had mine reprogrammed with a GOS custom burn, not very many people have it because it is soooo good, but if you get connections, that works... just don't get a TS... for your trucks sake, i beg you!
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
post #7 of 21 (permalink) Old 10-01-2007, 09:22 PM
I have a TS on mine and have ZERO problems. Shifts good, the worst is when the TC is locking up. Be nice guys.
USAFdieselman is offline
post #8 of 21 (permalink) Old 10-02-2007, 01:34 AM
Where can you see more GOS tunes at? 415 is impressive with just intake and exhaust.
Binder Man is offline
post #9 of 21 (permalink) Old 10-02-2007, 02:08 AM
CSIPSD's Avatar
2002 Ford F250 Crew Cab Long Box Powerstroke- Custom Burned 4 postion GOS Performance Chip, K&N Intake, 5" Expandit Turbo Back Straightpiped Exhaust- 415 HP
HAHHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHAHAH AHAHAHAHHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHHAHAHAHAAHHA HAHAHAHAHAHH Takes a deep breath... HAHAHAHAHAHAHHAHAHAHAHAHAHAHAHHAHAHAHAHAAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHA
He is not making 415 hp like that... doubt its even 315...
CSIPSD is offline
post #10 of 21 (permalink) Old 10-02-2007, 02:15 AM
My trucks probs got 350, 215 stock, plus 100hp tuner=315. Plus the twenty added from exhaust, 335, plus the twenty from the intake, 355, plus the FPR shim, .0001hp. 355.0001hp. See, simple math.
ckbed is offline
