Dp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Jays7.3, this thread has received 6 replies and been viewed 538 times.
post #1 of 7 (permalink) Old 10-09-2007, 02:36 PM Thread Starter
Jays7.3's Avatar
Dp
Ready to get it..Just was wondering how hard is it to install? I know there are some sites on ITP, but just wanted to ask some guys that have it..
Thanks for any help.
Early 99' f-250,7.3,auto,4x4,XLT
Dp-tuned,intake,eaxust,adrenaline HPOP,Itp over boost,bango bolts,HP crossover line,sun-coast trans
Jays7.3 is offline
post #2 of 7 (permalink) Old 10-09-2007, 03:18 PM
tjl
tjl's Avatar
I don't know about the super duties but it was a pain in the butt to put it in an obs truck. If I remember right the automatic trucks where easier than the manual due to the clutch being in the way.
Tim
'96 f350 cc dually, 5 speed w/ short throw shifter, stage 1 injectors, '03 sd intercooler, d66 turbo, DP Tuner F5 chip (stock, high idle, tow, econo, extreme) modified IDM, CCV mod, gutted EBPV
343 hp
670 tq
Dually Club #20
B.O.M.B. Squad #7
tjl is offline
post #3 of 7 (permalink) Old 10-09-2007, 04:00 PM
It was an easy install on my 02. I think it took about 45 minutes. The worst part for me was re-intalling the computer back through the firewall.
imported_ryan is offline
post #4 of 7 (permalink) Old 10-09-2007, 05:14 PM
99_stroker
look in the other 7.3 forum there is a link to the install video of the dp tuner that takes you to www.dieselmovies.com its much simpler than reading through directions
post #5 of 7 (permalink) Old 10-09-2007, 05:35 PM
Mafia Member #93
blk99's Avatar
It really is easy. took me about 30 minutes. And I didnt mount mine where they "recomend" to cause I didnt want it down by the steering wheel so I drilled a whole up on the dash and mounted it there.
And definatly use that vid it is much easier to go by!
Yeah manuals are twice a hard cause of the clutch and they have a different bracket the holds the PCM in.
~Jim
blk99 is offline
post #6 of 7 (permalink) Old 10-09-2007, 05:55 PM
It was a very easy install. Mine works great! but, I'm not real impressed with the way the mounting is. Your kinda on your own for mounting. My suggestion would be to cut a hole in your fuse panel cover so when the day comes to sell your truck, all you have to do is replace that cover.
Get some velcro tape to mount it to whatever panel you decide to use.
I also suggest cutting a hole in the back of the PCM cover to run the cable through. The instructions say to do this or just loop it out through the front which didn't work very well for me. I used a 1/2 in drill bit, drilled two holes side by side to run it through.
D-Man is offline
post #7 of 7 (permalink) Old 10-09-2007, 07:57 PM Thread Starter
Jays7.3's Avatar
Thanks alot guys.
Il give her a try.
Jays7.3 is offline
