ATS E Tuner vs. DP Tuner?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Akstroker, this thread has received 14 replies and been viewed 1713 times.
post #1 of 15 (permalink) Old 10-28-2007, 03:25 AM Thread Starter
Smile ATS E Tuner vs. DP Tuner??
Greetings,
My first post so here we go It's very apparent while scrolling through the posts that the general consensus is that DP Tuner is the prefered choice amongst most members. Does anyone have any experience or opinions regarding the ATS "E Tuner" programmer? I would love any feedback as I am trying to decide here within a few days (I happen to be parked outside of ATS in Arvada, CO with my 33' 5th wheel after just having their transmission, etc. installed in my truck)and know very little about chips/programmers.
Thanks a million!
Akstroker is offline
post #2 of 15 (permalink) Old 10-28-2007, 07:34 AM
Mafia Member #93
blk99's Avatar
Honestly, I dont know anything about the ATS E-tuner but I will add a vote for the DP-Tuner! They are one of the very best!
I dont know if your into the "black smoke craze" goin around these days but if you are here is a video of me messing around with the Highest setting DP-Tuner offers!
It is a little long cause I was by myself so I had to run back to the player.
http://www.youtube.com/watch?v=RCvZta3Abl8
~Jim
blk99 is offline
post #3 of 15 (permalink) Old 10-28-2007, 05:01 PM
Ewwwwwwwwwwwwwwwww. Good luck with that. I live not too far away and I won't put an ATS trans in my truck.
Pocket is offline
post #4 of 15 (permalink) Old 10-28-2007, 06:20 PM Thread Starter
Thanks for responding to my post.....why would you not use their tranny?
post #5 of 15 (permalink) Old 10-28-2007, 06:37 PM
strokin now cummin later!
Orangepstroke's Avatar
welcome to the diesel garage. I belive ats trannys are over priced. i personally haven't heard any complants about them. and i second the
dp tuner.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
post #6 of 15 (permalink) Old 10-28-2007, 06:52 PM Thread Starter
Thanks for the reply. As I'm new to this arena, are there any other companies out there making trannies like this that have at least a 3yr./150k warranty for less $$?
post #7 of 15 (permalink) Old 10-28-2007, 07:34 PM
yeah there are more companys out there. what did you spend? and are there any mods or is it just a factory rebuild?
Singles Club #42
post #8 of 15 (permalink) Old 10-28-2007, 07:48 PM
Yeah, good luck with that warranty. Have you read it?
They will void your warranty for nearly anything. Here's one example:
"The use of other than Factory or ATS TCM/PCM programming."
This one is funny, they now double your transmission maintenance costs. Normal service is 30K miles, now with an ATS trans, it's every 15K: "A qualified automotive shop must service the ATS transmission and/or 5Star Viskus Clutch Drive Torque Converter every year, or 15,000 miles (whichever occurs first) to ensure warranty for the full 3 year/150,000 miles."
Also if you want to cover the clutch pack under warranty in case of "over torque" you have to buy their Extreme clutch pack. How about build a transmission right to begin with that doesn't need an upgrade?
Want a good transmission? Get a BTS: www.brianstruckshop.com
We even have a BTS dealer here in Colorado, Rocky Horn: www.rspdiesel.com
When I got my BTS installed, Rocky told me "I dare you to break it". Try that with an ATS tranny.
Pocket is offline
post #9 of 15 (permalink) Old 10-28-2007, 08:28 PM
go with the dp tuner. you will love it
97STROKER_08 is offline
post #10 of 15 (permalink) Old 10-29-2007, 01:05 AM
Pro 2A
sirthomas's Avatar
so are the guys in Arvada,Co the same ones that make the ATS ported shroud housing?
01 F350 Lariat Crew Cab Short Box 4x4,4" Magnaflow turbo back exhaust,DIY 6637 air intake,Edge Juice with Attitude,Warn Manual Hubs,6.0 Trans Cooler,B&M Trans Temp Gauge,ATS housing,Turbo Master Wastegate Controller,BTS Transmission,CCV mod,coolant filter
TDG singles club member #106
TDG American club member #27
TDG B.O.M.B. squad member #25
Ridin' Dirty Club #32
sirthomas is offline
