Map line? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by skydog, this thread has received 3 replies and been viewed 544 times.
post #1 of 4 (permalink) Old 11-07-2007, 12:34 AM Thread Starter
Map line?
Guys i have a DP tune love it. But read about i need some thing on the map sensor for more boost??
Thank you Skydog
2001 Ford X with Racer X Trans and DP tuner
2003 Yamaha Rx1 with Turbo 300hp
2008 Yamaha Rtx Nytro Supercharged !!HAHAHA
25' Motion Cat twin 280 Merc offshores 118 mph
skydog is offline
post #2 of 4 (permalink) Old 11-07-2007, 04:07 AM
plainredtruck's Avatar
Images: 11
ITP's boost annihilator - Give Dennis a ring.
Won't give you more boost, just prevent the PCM from reading an "overboost" code.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 4 (permalink) Old 11-26-2007, 08:00 PM
Steel's Avatar
does the map line boost fooler really do that much? what kind of boost gains do you see?
2006 F350 CR/4R100 Fummins with Twins- 731HP 8-14-10--- Now with BIGGER TWINS
2009 Polaris Dragon 800 Race Gas Turbo- Winter Toy
"GOS Performance- Your Cummins Conversion Specialists"
800-620-4467
Check out our website here
GOS Performance Facebook
Steel is offline
post #4 of 4 (permalink) Old 11-26-2007, 08:06 PM
strokin now cummin later!
Orangepstroke's Avatar
it keeps to much pressure from goin to map senor. it the map senor reads over 20psi it tells the pcm to defuel. you might gain 1-2 psi if that.
Erik, 2001 psd 4x4 lariat ext cab pulling truck
Ts 140hp 6pos chip, 100hp split shots, stealth 2 pump,h2e turbo, tranny, afe stage 2,
5" exhaust turbo back, 10" stack, 3.9k mod on a switch, shimmed fpr,hx crossover hose, tc lock up switch. Custom weight rack and ladder bars, f550 springs, custom paint,5%+15% window tint, clear lights,custom billet grille, very big stereo, 20x10 moto meatals wrap with 33x13.50x20 ss iroks
1996 2500 12v 2wd auto reg cab, flat bed, afc mods, sdx 140hp sticks, 4gsk, 60lbs springs, 191dv's, head studs, 16* timing, phat shaft 62/65/14 no plate, exhaust, intake, tanny, auto meter, adjustable overflow valve.
Singles Club #42
Orangepstroke is offline
