a little confused - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 02bigstrokin, this thread has received 9 replies and been viewed 1044 times.
post #1 of 10 (permalink) Old 11-07-2007, 11:07 PM Thread Starter
a little confused
i am wanting to get a new chip for my 02 psd and i am a little confused about something. what in the hell is the 18k mod. do you run it with other chips or by itself or what? im thinking the dp tuner is the best from all im reading. so can i run te 18k and the dp? also the oil crossover line that dfuser sells, does that make a difference? thanks in advance for any replies.
03 cc, sb 2500hd lb7. 68,000 miles, afe stage 2, ppe boost increase valve, hypertech programmer, 285's k/o's and way more to come!
02bigstrokin is offline
post #2 of 10 (permalink) Old 11-08-2007, 12:34 AM
The 18k mod tricks the computer into pumping up the oil pressure to your injectors. But I dont know if you can run the dp and the 18k mod
jebsurf is offline
post #3 of 10 (permalink) Old 11-08-2007, 12:47 AM
Mafia Member #93
blk99's Avatar
Jebsurfer is right, The 18K mod ups the ICP (injector control pressure) which makes the fuel atomize better and in turn gives you added HP.
You can run the 18K by itself and you CAN run it with the DP tuner. You just need to tell Jody that you have it when you order you DP chip.
Honestly, I am not fond of the Dfuser crossover line (SORRY BILL!) because I like a hard line instead of hose. The only place I know of that sells the hard line one is ITP Diesel.com and it is like $70. Again that is my opinion and I am sure there is absolutly nothing wrong with Dfuser's!
~Jim
blk99 is offline
post #4 of 10 (permalink) Old 11-08-2007, 10:40 PM Thread Starter
thanks ill ask jody aboutwhat he thinks when i order the chip.
post #5 of 10 (permalink) Old 11-09-2007, 05:33 AM
Blk99 is right, you can run the 18k mod with the chip, but personally I wouldn't. If I'm not mistaken one of the jobs of the chip is to increase the ICP so why do it twice? The 18k mod is really cheap and fairly easy but I kind of don't think it will make all that much difference with the chip as well, but like you said, ask Jody because he WILL know. Good luck and let us know how you like the chip when you get it.
crfracer is offline
post #6 of 10 (permalink) Old 11-09-2007, 01:37 PM
Jody's tunes already call for higher ICP, and his tuning tables for ICP, fuel, shifting, etc all work together. It's best to run the chip by itself rather than stack with an 18K mod.
Pocket is offline
post #7 of 10 (permalink) Old 11-09-2007, 04:37 PM
Mafia Member #93
blk99's Avatar
Of course, it is best to run just Jody's chip but I was just answering his question of, could you run them together.
blk99 is offline
post #8 of 10 (permalink) Old 11-09-2007, 05:42 PM
, you kinda answered your own question when you said "it's best to run just Jody's chip" :tango
The 18K mod fools the PCM into thinking the ICP is low, so the PCM bumps up the pressure. Since Jody's chips already bump up the ICP pressure, then the chip is now going to raise the ICP even higher than what the tuning originally calls for. The problem is that on a single stock HPOP, it can only put out so much oil. If the chip is calling for as much oil as the HPOP can put out - then you stack the 18K mod on top, now the HPOP isn't keeping up with what is demanded and you'll have a truck that will flatline on power in the upper RPM band. A long time ago some folks ran 18K mods stacked with Jody's chip on a dyno and found that they lost peak power.
In short, can you run them together? Yes. Should you? No.
Pocket is offline
post #9 of 10 (permalink) Old 11-09-2007, 10:05 PM Thread Starter
thanks for all the replies, ill just get the chip and be done with it>
post #10 of 10 (permalink) Old 11-09-2007, 11:49 PM
I could have not said it better myself:Thumbup: ! Good info
jebsurf is offline
