Resistor inline with Map Sensor??? Anyone? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by surftouch, this thread has received 9 replies and been viewed 5315 times.
post #1 of 10 (permalink) Old 11-12-2007, 12:56 PM Thread Starter
i bought my truck used, and its got some mods done to it, But has anyone ever heard of putting a resistor in the map sensor? they cut one wire at the plug, then put a resistor on the cut part and jumped it to another wire??...i took it off and its got lag, just curious if anyone ever heard of this:shrug: :shrug:
surftouch is offline
post #2 of 10 (permalink) Old 11-13-2007, 01:04 AM
i used one until i got a map regulator. It worked ok.
lukecline is offline
post #3 of 10 (permalink) Old 11-15-2007, 09:21 PM
The Oracle
BigRed97's Avatar
Send a message via AIM to BigRed97
a little off topic but i have also heard of grounding the green wire from the map...what does that do?
e99 leveled on 35s
250/80, modded s300, studs, springs, push rods, adrenaline, swamps tuning, racerx trans
BigRed97 is offline
post #4 of 10 (permalink) Old 11-15-2007, 11:20 PM
Putting the resistor in line with the map sensor makes the computer think that your boosting 20lbs all the time. This makes your throttle response like a gas truck, and is also why the truck feels like it lags now, cause thats how they are stock. My buddy at the local ford dealership has it on his truck, and im doing it to my truck this weekend. Ill post back with the results.
PowerChoker32 is offline
post #5 of 10 (permalink) Old 11-16-2007, 05:54 AM
Dave from Bd diesel sent me one to try on my truck and i like it. With my edge evo II showing boost the map sensor only see's 13 lbs. of boost. never throws a over boost code. Truck seems to run good on all settings as well.
2000 Ford F250 ext cab 4x4 6 spd. PHP tuned, Glow shift gauges ( fuel, egt, boost), B and W turnover ball, Tymar intake, 5 inch mbrp exhaust w/ 6 inch tip.
tholt846 is offline
post #6 of 10 (permalink) Old 11-17-2007, 06:51 PM Thread Starter
Yeah it Deff made it have No lagg and better Throttle response, but since my WIfe lost the resistor, I cant install it again,lol....But it does work for anyone who wants to try it:smoke
post #7 of 10 (permalink) Old 11-18-2007, 03:25 AM
OBS
where do i find an "how to" on this?
97 F-250 7.3 psd 4x4: homemade Intake, fpr mod, IDM mod, 18k mod, HX mod, a pillar w/ 3 autometer gauges, 3" downpipe, minus muffler and cat.
stroker_baldy is offline
post #8 of 10 (permalink) Old 11-18-2007, 04:40 PM Thread Starter
I can tell you how to do it, but I dont know what resistance the resistor is. Let me know if your still interested.....But I dont know if you want to tamper with putting in the wrong resistor....
post #9 of 10 (permalink) Old 11-18-2007, 10:44 PM
OBS
hopfully someone will chime in w/ resistor size. which wire do i tap into?
post #10 of 10 (permalink) Old 11-24-2007, 02:37 PM
A buddy of mine has a early 99. He put the 100k ohm resistor on his map sensor and back pressure sensor and it makes his truck snappy as hell. But i put it on my truck and the things more of a dog than stock and only boosts like 13 psi. I think its a trial and error thing getting the right resistance. But i have a SCT with elite files on my truck now, all i did was unplug the connector to the wastegate controller and my trucks boostin 27 psi all day long.
